Alarm not Functioning
Old Sep 22, 2005 | 10:20 AM
Patience's Avatar
anyone else having any ssues with their motion alarm? mine doesn't work on either side of my convertible--any trouble shooting ideas? thanks
Old Sep 22, 2005 | 07:45 PM
RMac's Avatar
I assume you have the top up when you're testing it?
From other posts on here, the motion sensors don't work with the top down.
Old Sep 22, 2005 | 07:59 PM
Donna's Avatar
Queen Of Nascar
I have not been able to set mine off either and I read the manual. I figure I'm just doing something wrong. If you walk up to the car and rock it, isn't it supposed to go off?
Old Sep 22, 2005 | 08:24 PM
RMac's Avatar
No... the alarm won't typically go off by rocking the car...
(from the manual
When the vehicle is locked and armed, the active anti-theft system
monitors the following:
• Doors
• Hood
• Trunk
• Movement inside the vehicle
• Change in vehicle inclination
(end of manual pasted text)
When it's armed, the alarm will sound if a door, the hood or trunk is opened.
It will also go off if there is movement inside of the vehicle (you can test this one pretty easily by arming the alarm with your windows down, then reaching inside the vehicle and waving your arm... the alarm should then go off).
It will also go off if the vehicle's incline changes (for example, if someone tries to tow the car away).
Old Sep 22, 2005 | 08:58 PM
Donna's Avatar
Queen Of Nascar
Thanks I will try that.
Old Sep 26, 2005 | 09:39 AM
jdruid's Avatar
It would make most sense for a vert that it would work with the top down. Sometimes Ford just kills me by not doing everything 100%.
Old Sep 26, 2005 | 07:25 PM
StangNut's Avatar
No it wouldn't.
Then it would have so many false alarms, it would be useless.
They did it just right.
Old Sep 28, 2005 | 10:49 AM
Patience's Avatar
rmac thanks---no, it was with the top down, but i could se where false alarms could happen--aka windy days---i'll put the top up and try it---the incline change is a great feature too----
Old Sep 29, 2005 | 12:41 PM
Paris MkVI's Avatar
It really is a good factory system. Ultimately, none of these will stop determined thieves from stealing the car, but it sure will make it hard for them to be inconspicuous about it!
They usually can't hotwire these cars anymore because of the RFID keys. So they just flatbed tow them. But our systems will go off when they try that too.
May 3, 2026 05:42 AM
PonyMuscletang13
Sep 26, 2015 02:33 PM
BigHoss
Sep 21, 2015 10:03 AM
Sep 16, 2015 06:44 PM
