Adding Power Seats
Adding Power Seats
How would I add power to a power drivers seat if the car was not installed with it? I used to have a manual seat track and now have a power one for the drivers side, and need to know how to add power. I have tried to find out what harness I would need but ended up with too many "maybe's".
Is there a way to add power from the fuse box?
if you cant read a wiring diagram perhaps trying to wire in your own power seat probably isnt the best idea you ever had.
But according to the wiring diagram it appears that you just need to find a power supply and a ground, two wires, find an empty fuse slot, put a 30a fuse in it, run your power wire, then ground wire you can just run to one of the bolts used to secure the seat, and presto power seat
Rando
Aug 25, 2021 11:12 AM
