2008 Mustang GT, replaced SJB and now the OEM HID are flickering
Old Nov 21, 2025 | 01:47 PM
Rebelk81's Avatar
Hi I’m new here and have ran into an issue. I replaced the SJB in my 2008 Mustang GT but now the HID OEM relay is buzzing and the HID lights are flickering. I reinstalled the old SJB and those issues stopped but now my radio and power accessories don’t work which why I swapped the SJB. The new is a match to the old one. Don’t know what to do. Help !!
Old Nov 22, 2025 | 08:16 AM
05stangkc's Avatar
While Your Numbers May Match??? You Said They Were a Match You Do Mean ID Numbers Match Not Simply Look of Unit???
A Pic of The Tags From Both SJB'S Would Be Helpful!
If You Have an Early SJB in Your Later Car it May or May Not Program To Car!
I Don't Suppose You Have Vin of Donor Car??
Your SJB When Changed Many Times Needs To Be Reprogrammed!
Likely The Donor Car Did Not Have HID's!
https://themustangsource.com/forums/...cement-531649/
KC
Old Nov 22, 2025 | 08:46 AM
Rebelk81's Avatar
KC
yes the engineering numbers where a match not just look alike. Both my car and the donor car are 2008 Mustang GT. After reaching out to the previous owner the two differences is mine is a convertible and you’re right his did not have factory HID lights.
Old Nov 22, 2025 | 08:54 AM
05stangkc's Avatar
Definetly Gonna Need a Reprogram!
Off To The Dealer or a Good Shop That Can Download AS-BUILT Data. These Days a Forescan Setup Can Do The Trick and as Built Data is Available Through Motorcraft Service!
Let Me Find another Link For You!
Although in 2010-2014 Section Information as Far as As-Built Procedure is The Same!
https://themustangsource.com/forums/...topics-551889/
KC
PS
I Would Think The Rear Window Function For Top Down Would Not Work With New Sjb as Well.
Old Nov 22, 2025 | 03:28 PM
Rebelk81's Avatar
KC
PS
Youre correct it did not work either.
Dan12z
05-09 Exterior Modifications
Oct 19, 2018 03:23 PM
Ruphix
Ford OEM Parts {Oem Ford Parts Information & Links}
Apr 4, 2008 01:28 PM
metroplex
Dec 28, 2007 10:29 AM
metroplex
Dec 24, 2007 02:12 PM
jmanpatsfan
May 13, 2007 01:37 AM
