2008 Mustang GT, replaced SJB and now the OEM HID are flickering
Hi I’m new here and have ran into an issue. I replaced the SJB in my 2008 Mustang GT but now the HID OEM relay is buzzing and the HID lights are flickering. I reinstalled the old SJB and those issues stopped but now my radio and power accessories don’t work which why I swapped the SJB. The new is a match to the old one. Don’t know what to do. Help !!
While Your Numbers May Match??? You Said They Were a Match You Do Mean ID Numbers Match Not Simply Look of Unit???
A Pic of The Tags From Both SJB'S Would Be Helpful!
If You Have an Early SJB in Your Later Car it May or May Not Program To Car!
I Don't Suppose You Have Vin of Donor Car??
Your SJB When Changed Many Times Needs To Be Reprogrammed!
Likely The Donor Car Did Not Have HID's!
https://themustangsource.com/forums/...cement-531649/
KC
KC
KC
KC
Definetly Gonna Need a Reprogram!
Off To The Dealer or a Good Shop That Can Download AS-BUILT Data. These Days a Forescan Setup Can Do The Trick and as Built Data is Available Through Motorcraft Service!
Let Me Find another Link For You!
Although in 2010-2014 Section Information as Far as As-Built Procedure is The Same!
https://themustangsource.com/forums/...topics-551889/
KC
PS
I Would Think The Rear Window Function For Top Down Would Not Work With New Sjb as Well.
KC
PS
KC
PS
KC
PS
Youre correct it did not work either.
Ruphix
Ford OEM Parts {Oem Ford Parts Information & Links}
Apr 4, 2008 01:28 PM
metroplex
Dec 28, 2007 10:29 AM
metroplex
05-09 Exterior Modifications
Dec 24, 2007 02:12 PM
