05-09 Convertible Mod for Comfortable Ride??
Old Jan 11, 2018 | 04:16 PM
cec's Avatar
cec
Smile 05-09 Convertible Mod for Comfortable Ride??
Has anyone completed an upgrade to a 2005-2009 Convertible that provided a more comfortable ride??
Old Jan 11, 2018 | 05:37 PM
SpectreH's Avatar
I doubt you'll get a good answer. Most people modify the suspension to handle better.
Old Jan 12, 2018 | 06:35 AM
You can probably put some smoother or more forgiving shocks and struts on there. Get some tires with more side wall and maybe a little less width.
Old Jan 12, 2018 | 11:50 AM
Bert's Avatar
Yeah I think the tires would be my first move. For a softer ride you want more sidewall, and/or a softer sidewall. You can increase the sidewall height by going with higher aspect ratio -- that is the second number in the size, like 245/40. If you don't change the wheels, this will increase the overall diameter of the tires which is generally not a problem for clearance but it will throw the speedometer off a bit. Or you can change to smaller diameter wheels and bigger sidewall tires to maintain the same overall diameter. Also some specific tire makes/models are known for a softer or smoother ride. Tire Rack could probably help you with that.
A shop that specializes in shocks/struts might be able to make a recommendation on some softer ones but most people go in the other direction so I am not sure about this.
roush1582
05-09 Exterior Modifications
Oct 27, 2012 08:19 AM
Ltngdrvr
Mar 19, 2012 04:16 PM
Imatk
05-09 Interior and Audio Mods
May 16, 2008 10:25 AM
lodom
Jul 4, 2007 02:17 PM
cyoon
Jul 21, 2005 12:25 AM
