Has anyone completed an upgrade to a 2005-2009 Convertible that provided a more comfortable ride??
SpectreH
1/11/18 05:37 PM
I doubt you'll get a good answer. Most people modify the suspension to handle better.
Glenn
1/12/18 06:35 AM
You can probably put some smoother or more forgiving shocks and struts on there. Get some tires with more side wall and maybe a little less width.
Bert
1/12/18 11:50 AM
Originally Posted by Glenn
(Post 7024174)
Yeah I think the tires would be my first move. For a softer ride you want more sidewall, and/or a softer sidewall. You can increase the sidewall height by going with higher aspect ratio -- that is the second number in the size, like 245/40. If you don't change the wheels, this will increase the overall diameter of the tires which is generally not a problem for clearance but it will throw the speedometer off a bit. Or you can change to smaller diameter wheels and bigger sidewall tires to maintain the same overall diameter. Also some specific tire makes/models are known for a softer or smoother ride. Tire Rack could probably help you with that.
A shop that specializes in shocks/struts might be able to make a recommendation on some softer ones but most people go in the other direction so I am not sure about this.
