Tranny swap, fix, rebuild?
Old Jun 15, 2014 | 02:44 PM
wawanesamuscle's Avatar
Hello! I have a 2002 mustang gt. I was told when I got it that it has a damaged 2nd gear synchro. Because of this I got a great deal but now I'm looking to fix it. So what happens is, every gear works great, good clutch, but I can only get from first to second if the Rpms are below 2g. Any higher and it will grind and not go in till the Rpms have dropped. Once in second everything is fine. That cars perfectly drivable but this is something I obviously would like to fix. But is it fixable? Or is it more cost effective to buy a 350 dollar used one from the wrecker? I feel I can install a tranny but have no experience in fixing them. Just looking for opinions! Thanks!
Old Jun 16, 2014 | 10:39 AM
I'm not really sure if it can be fixed of not, but I will say this, transmissions are very precise in their build. If you haven't worked on them before, I'd be hesitant to do so, especially if it's a gear synchro.
Old Jun 17, 2014 | 06:25 AM
THCracing's Avatar
Good morning,
It can be fixed, but will cost a lot more than getting one from the junk yard. If you are able to install it yourself then that is the way to go.
Old Jun 17, 2014 | 06:36 AM
THCracing's Avatar
Just for your information, the parts to repair second gear only are around $850.00 before labor. Let me know if you need more help. Depending on your transmission the parts may not be available anyway.
Ray11
Sep 25, 2015 12:43 PM
BigHoss
Sep 21, 2015 10:03 AM
Grabber5.00
Sep 13, 2015 06:53 AM
