traction control switch broken
Old Jun 24, 2006 | 03:31 AM
2000gTstang's Avatar
all of a sudden my traction control switch doesnt work to turn off tc. the light doesnt come on or anything. is there any way i can just turn it off or do something, without ordering a new switch right away? thanks
Old Jun 25, 2006 | 08:48 AM
mudshuvel319's Avatar
If you have a tuner (SCT, Predator, etc.) you may be able to turn it off with that, but I'm not sure. Other than that, I think you're just gonna have to fix whatever the problem is.
Old Jun 26, 2006 | 06:09 AM
tricky02GT's Avatar
I agree with Dan. Are you sure it is the switch that is broken and not a break in the wiring?
If you go with the tuner you can do numerous things for example turning off traction control. You can also 'juice' up the HP a little as well.
I would remove the switch and check it out before ordering a new one just in case it is a break in the loom.
Good luck.
Old Jun 26, 2006 | 07:41 AM
TJ4Cam's Avatar
Good luck.
I agree, check the switch itself first..also was there anything else on the car that went out at the same time or close to that time?
Old Jun 27, 2006 | 02:54 PM
nope, thats the only thing, the reason i think the switch went out is because for about 6 months before it totally stopped working, the switch always didnt work, like you had to hit it a few times. and them sometimes the orange light wouldnt come on, but itd be off..so ill be sure to check the wires..and if they are intact. i think im just gonna get the tuner. itd be good do to anyway.
yabutt
Oct 23, 2015 01:05 PM
Sep 8, 2015 10:45 AM
