theturses
Old Jun 9, 2016 | 07:28 AM
theturses's Avatar
theturses
94 gt died while driving, wont start but cranks. no spark. also battery drains fast and when charging strong hum comes through speakers when key is off...help
Old Jun 9, 2016 | 03:29 PM
Evil_Capri's Avatar
Perhaps a bad distributor control module and test your alternator?
Old Jun 10, 2016 | 05:10 AM
Cavero's Avatar
I would've said a bad alternator or battery but that buzzing makes me think a short somewhere. Then again alternator problems can manifest themselves in weird ways. Voltage gets low and electronics can do strange things. +1 on getting alternator checked.
I'd also pull the fuse for the radio and see if that does anything with battery drain.
So with the buzzing, is it with the radio still on after you shut off the car? Or with everything off? Does it do it only on AM/FM or CD/cassette/aux/etc? If it's AM/FM, I wonder if the antenna wire is picking up interference from whatever could be shorting.
-- edit--
Reading the post again I'm really thinking its a short. If everything's cold and you charge it, are there any areas getting warm?
Old Jun 10, 2016 | 04:20 PM
Cavero's Avatar
Originally Posted by Gravydog
With mine, the cd player would make the loading sound, even with the engine off, & you just get in it; they are cheap junk, & it kept draining my battery, so i got a new battery,
& THAT was bad, the (barely) cold weather caused the battery case to crack, & the whole battery was coated with acid,
so they gave me a new battery, & i pulled my radio fuse.
I want to remove just my cd player, but apparently it's all one unit
I see what you're saying. With what the OP's saying though, the speakers themselves are making the buzzing sound, which with fast battery drain and no spark is what makes me think high power/short.
OP- please let is know what you find
3point7
Jul 1, 2016 02:00 AM
usaf1965
1994-2004 V-8
Jun 9, 2016 07:32 PM
mikes70mustang
2012-2013 BOSS 302
Jun 8, 2016 05:52 AM
junkman27
May 21, 2016 01:02 AM
Jim74656
May 16, 2016 11:14 AM
