Tachometer not working
Old Aug 21, 2013 | 09:56 AM
Davescobra's Avatar
I have a 97 cobra and the tachometer works sometimes, does anyone have an idea what the problem might be ?
Old Aug 23, 2013 | 04:40 PM
13boss302's Avatar
When you say it doesn't work, describe. There was a TSB for some late model 96 and early 97 Mustangs. It had to do with the odometer not moving and a slight rattle noise under the column. It was about there not being enough grease in the cable and the cable would rattle due to the vibration of the metal cord not moving in the housing. I had a 96 GTS that had this problem. The dealer had to regrease the cable to get it to work. The speedo and tach would move, just not the odometer.
Old Aug 23, 2013 | 11:46 PM
Davescobra's Avatar
Most of the time it won't move at all and then every so often it would show the true rpm and then sometimes the tac will go crazy and bounce from the start to the end of the gauge a few times and then stop working again.
Old Aug 24, 2013 | 03:58 AM
Evil_Capri's Avatar
Moving thread to 'SN95' section . . .
Old Aug 24, 2013 | 06:35 AM
flade's Avatar
The tach has nothing to do with the speedo and odometer. They are mechanically driver. Mother tach is electrical. Most likely you have a bad electrical connection.
Old Aug 28, 2013 | 09:27 PM
Davescobra's Avatar
I wouldn't even know where to start with the electrical
Old Aug 28, 2013 | 10:15 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
That's my specialty.. If you were in the dfw area in Texas I would help
Old Aug 28, 2013 | 11:24 PM
shaunrc's Avatar
I suggest you get a chiltons and look it up in there most likely it will have it and the procedure I wouldn't really take someone's word for it that thinks they know what they are doing
Old May 29, 2022 | 05:01 PM
Jkb97GT's Avatar
Check your connections on the back or your instrument panel. Mine did that after I changed out bulbs. My connections were loose.
09-gt/cs
Oct 15, 2015 10:03 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Sep 24, 2015 08:15 PM
