Starting problems...?
Old Sep 15, 2014 | 04:56 PM
slow02vGT's Avatar
Hey guys got a question for ya. Just about every other time I start my car it'll die and back fire. I had auto zone put there cheap computer on it and it said it was a cam sensor, I changed it and nothing changed. I wanted to get some suggestions before I went any further. I'm thinking it's my timing chain, any ideas?
Old Sep 16, 2014 | 05:21 AM
Sjnagy's Avatar
I have the same problem. I changed my chains but still every now and then it still happens.
But you should still do you're chains because I did mine at 145,000 and the chain was riding threw the shoe. I had a spot where the chain wore all the way threw on the passenger side.
Good luck
Old Sep 16, 2014 | 08:41 AM
slow02vGT's Avatar
Originally Posted by Sjnagy
I have the same problem. I changed my chains but still every now and then it still happens. But you should still do you're chains because I did mine at 145,000 and the chain was riding threw the shoe. I had a spot where the chain wore all the way threw on the passenger side. Good luck
Thanks for the info, I might change them this weekend then. Any tips? Also would you take it to ford and have them hook it up? See why my engine light is on?
Old Sep 16, 2014 | 01:04 PM
Sjnagy's Avatar
I think autozone can check for codes. As for the chains just take you're time and buy them from Ford. You can check the shoes on how much wear you have by pulling the valve covers and looking down. The only problems I had were my valve cover gaskets were not correct I think it was just mine. Also I was on a stroke on the left side and my cam slipped so I had to be extra careful.
Old Sep 16, 2014 | 06:01 PM
I had the same problem, and as weird as it sounds, replace your alternator. I replaced half the sensors in my engine, and even the car's computer...a 5 minute alternator swap later, I haven't had the problem since. There's been a couple people here with the same problem, and solution.
Old Sep 16, 2014 | 06:06 PM
slow02vGT's Avatar
Thanks for the reply! I had auto zone hook up my car and they said cam sensor and when he hit the "how to solve this problem" button it said replace alternator. We figured it couldn't be right. But I'll definitely try it now thanks!
Old Sep 16, 2014 | 09:51 PM
Yup, it's the damndest thing I've ever seen. I tried it pretty much as a last alternative, what the hell kind of thing. The only thing I can think is that the alternator malfunctioning is sending some odd and messed up electrical signals through the electronics.
Old Sep 18, 2014 | 01:32 PM
slow02vGT's Avatar
Work got rained out today so I bought an alternator and put it on. Car runs and starts much better, still trying to figure out how it fixed it lol. Thanks for the info guys.
09-gt/cs
Oct 15, 2015 10:03 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
GLOCKer
Sep 28, 2015 05:20 PM
