Rear driver side quarter window not rolling down
So I'm trying to roll my windows down so i can lower my convertible top and I can't get the quarter window on the drivers side to roll down, all the other windows go down so it's not the fuse. Does anybody have any suggestions on how to fix this. I've heard you can reset the windows but am not totally confident on how to do that or whether that will work.
Here are Some Shop Manual Pdf's To Check Out! See Below Vids!
Be Advised I Will Tend To Overpost Information So Others With Similar But Not Exact Issue Can Benefit!
So You Likely Have a Bad Switch, Bad Connection, Bad Motor or Fouled Regulator.
So Here is a Little Test to get You Started. In a Shaded or Dark Area Turn on Ignition to Operate Windows. Turn on Your Lights. Activate Your Good Quarter Window. Check Your Battery Gauge in Dash if You Have One and See if it Moves as You Hit Switch. If Not With Lights on and Door open So Interior Lights are On See If The Dim Just a Sec When You Activate Good Window. Now If You Can See These things, Now Try That with The Bad Window. If Nothing Happens That Means No Power at Switch Likely. Now if They Dim, Try Putting Your Ear to Area Just Below Window in side Car and See If You Hear The Motor Running at All. If So The Regulator or Gear in Window Motor has Issues.
Now Back To Switch. If It's Dead You May be Able To Clean With Contact Cleaner and Get Some Movement. Spray into The Bad Section on Switch and Hope For The Best. It Can Be Done While Installed But Would Be Best if Removed. Hope You Can Follow My Early Morning Explanation! Oh Also When Activating Bad Switch Try Using Thumb & Fore Finger To Put a Bit of Rocking Motion into Activating Switch. Sometimes You Can get a Bite of the Inside Contacts That Way Vs Just The Fingertip Activation.
Anyhoo Best of Luck!
KC
Oem Ford Window Switch For Reference Part is Obsolete
https://www.fordpartsgiant.com/parts...z-14529-b.html
Rock Auto Switch
https://www.rockauto.com/en/moreinfo...eXWn68GUNltrk1
Oem Regulator For Reference
https://www.fordpartsgiant.com/parts...323201-aa.html
Rock Auto Regulator
https://www.rockauto.com/en/partsear...R3Z-6323201-AA
Oem Window Motor For Reference
https://www.fordpartsgiant.com/parts...tra2=&filter=()
Rock Auto Motors
https://www.rockauto.com/en/catalog/...dow+motor,1516
Be Advised Vids are Generic and More Exact Ones Can Be Found on Youtube Usually. But Regardless Good Info If You Are New To Window Motor Work!
KC
Rock Auto Switch
Rock Auto Regulator
Rock Auto Motors
marcosMadrid
Jun 10, 2025 04:46 AM
Brian Berthold
Aug 24, 2013 08:24 PM
94tbird
May 16, 2005 09:21 PM
