Radiator coolant leak
Old Mar 1, 2013 | 12:09 PM
mccolaus000's Avatar
I have a 95 gt and the coolant is slowly leaking. How do I fix this?
Old Mar 1, 2013 | 01:33 PM
Getportfolio's Avatar
Check for cracks first and how bad they are.
Old Mar 2, 2013 | 01:03 AM
bluethunderhorse's Avatar
Water pump could be leaking from the weep hole
Old Mar 2, 2013 | 07:40 AM
BRADGTCS's Avatar
are you sure that your not puking extra out of the coolant reservoir. it could be so many things. maybe your cap pressure sucks. maybe your braze beads are old and leaking. Take it in and pressurize it if you can not find the leak while it is hot.
Old Mar 2, 2013 | 10:25 AM
I can't find any cracks. I had to fill once cuz the low coolant light came on this month so it's not an over flow
Old Mar 2, 2013 | 10:35 AM
Barr's stop leak. Go find it at your parts store. If you've got a small leak, it'll stop the leak.
I've had a couple of small leaks I couldn't find, and that solved the issue.
Old Mar 2, 2013 | 04:48 PM
Will do thank you
Old Mar 25, 2013 | 09:26 PM
I guess it's a thermometer gasket? Or temperature gasket? Can't remember what it was called and still learning. Either way there is no coolant in the oil yet. Anyone know how hard it is to replace this?
Old Apr 16, 2013 | 01:17 PM
Turned out it was the timing chain cover gasket. Small at first then blew. Had to replace 2 radiator hose as well. 10 hours and $50 later no leak
Gill5oh
Oct 6, 2017 10:50 PM
Cobiecane
Oct 23, 2015 08:44 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Evil_Capri
Sep 25, 2015 12:56 PM
