Po 350 code on 01 GT
My 01 GT keeps coming up with Po 340 code. I already changed out the socket and cam position sensor and it still pops up. Any suggestions of what this problem could be? And also my car is back firing when I start it cold or hot. Any suggestions, thanks in advance..
Could be some bad wiring going to the sensor making the computer itself think it's the sensor, the backfiring when starting is prolly due to this code that's how the car determines ignition timing
Seems like a common problem. Check out this thread: http://www.allfordmustangs.com/forum...rror-code.html Might have something to do with the alternator...
As nathan said, this seems to be becoming quite a bit of an issue. We both have the same code, as does the OP. My dealer scanned it and said it was a PCM issue. I haven't gone any further with it yet however.
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Originally Posted by cdynaco
fwiw, I remember reading on the Cruiser forums a year or two ago, that they posted a number of defective replacement cam sensors and constant P0340 errors. Maybe a bad batch here? Any way to test them?
Another problem I'm having is that the abs light is on, checked all of the sensors and and everything looks good. Im wondering if this is another for issue for these years.
Antigini-GT/CS
10/5/15 09:43 AM
