Po 350 code on 01 GT
Old Nov 24, 2011 | 03:26 PM
01comegetsome's Avatar
My 01 GT keeps coming up with Po 340 code. I already changed out the socket and cam position sensor and it still pops up. Any suggestions of what this problem could be? And also my car is back firing when I start it cold or hot. Any suggestions, thanks in advance..
Old Nov 24, 2011 | 03:53 PM
AlsCobra's Avatar
A Man Just Needs Some....
I usually would change the cam and crank sensors together. Really difficult to test which one is bad. But I didn't look up your code yet.
Old Nov 24, 2011 | 04:05 PM
Yea I forgot to mention I changed that sensor also and still no fix.
Old Nov 25, 2011 | 12:32 AM
scotti78's Avatar
Could be some bad wiring going to the sensor making the computer itself think it's the sensor, the backfiring when starting is prolly due to this code that's how the car determines ignition timing
Old Nov 25, 2011 | 12:51 AM
Blue Notch's Avatar
Seems like a common problem. Check out this thread: http://www.allfordmustangs.com/forum...rror-code.html Might have something to do with the alternator...
Old Nov 26, 2011 | 11:30 AM
Thanks I'll swap out the alternator and hopefully that's the problem.
Old Nov 26, 2011 | 12:08 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Title says p0350 and in your op you put p0340. What code are we dealing with here?
Old Nov 27, 2011 | 03:15 PM
I meant to put Po 340 I tried to edit it but it wouldn't let me.
Old Nov 28, 2011 | 08:35 AM
Bear Eats King...
Bear ****s Bone
Cam position sensor code. I think you have a damaged wire. Let me get you some wire diagrams as well as diagnostic time tables.
Old Nov 28, 2011 | 09:00 AM
how many miles are on it?
Old Nov 28, 2011 | 07:43 PM
Ive changed the plug itself
Old Nov 28, 2011 | 07:44 PM
I've changed the plug because my clip was broken, and I have 168k on it.
Old Nov 28, 2011 | 07:46 PM
As nathan said, this seems to be becoming quite a bit of an issue. We both have the same code, as does the OP. My dealer scanned it and said it was a PCM issue. I haven't gone any further with it yet however.
Old Nov 28, 2011 | 08:41 PM
Old Nov 28, 2011 | 08:42 PM
Bear Eats King...
Bear ****s Bone
Didn't realize this was common on the new edge stangs... Hopefully its not a Pcm because that's not cheap. If anyone is near by I will do some free diagnostics to see if I can pin point it.
Old Nov 28, 2011 | 08:43 PM
Bear Eats King...
Bear ****s Bone
Originally Posted by cdynaco
fwiw, I remember reading on the Cruiser forums a year or two ago, that they posted a number of defective replacement cam sensors and constant P0340 errors. Maybe a bad batch here? Any way to test them?
Yes. Using a dmm which is about 15,000 dollars... We have one at work.
Old Nov 29, 2011 | 01:45 PM
Another problem I'm having is that the abs light is on, checked all of the sensors and and everything looks good. Im wondering if this is another for issue for these years.
Old Nov 29, 2011 | 05:58 PM
Blue Notch's Avatar
My ABS light was on a year ago and it turned out the wire going to the sensor was rubbing up against the tire.
May 3, 2026 05:42 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
boz
Oct 1, 2015 04:47 PM
