Oil cooler replacement
Old Dec 22, 2012 | 12:05 AM
McNassty's Avatar
Okay so I have a '95 Cobra and my oil cooler is leaking at the engine and Ford doesn't make this part an gasket any more so I'm thinking about buying this kit from eBay my question is has anyone tried it? Is it alright? I just want my oil leak to stop, I will post the link in a min
Old Dec 22, 2012 | 12:08 AM
McNassty's Avatar
http://item.mobileweb.ebay.com/viewi...id=84953136888
Old Dec 22, 2012 | 12:10 AM
McNassty's Avatar
If you haven't tried this kit do you have any suggestions for any other kits or parts?
Old Dec 23, 2012 | 08:58 AM
bluethunderhorse's Avatar
I don't think I would trust an ebay cooler. Most likely it's made in china, and will fail in a few months. if you're on the cheap try this. Don't mind that it says transmission cooler, an oil cooler is an oil cooler.
http://www.summitracing.com/parts/fl.../model/mustang
If not this
http://www.summitracing.com/parts/der-13700
http://www.summitracing.com/parts/der-15752
Old Dec 23, 2012 | 09:49 AM
McNassty's Avatar
I don't need the cooler I actually just need a new plate and gasket but they don't make them anymore. The kit I posted I don't really want to use because I really don't trust eBay parts but it will replace my cooler plate and I could relocate my oil filter but I also don't really know where to relocate the filter to either
Old Dec 23, 2012 | 10:01 AM
If you get a relocate kit you can attach the filter to the frame rail close to the swaybar mount
Old Dec 23, 2012 | 10:38 AM
McNassty's Avatar
I'm gonna have to look under there and look once i get the kit if I get it but thank you that sounds like a good place. Have you ever mounted a filter there before? Any troubles?
Old Dec 23, 2012 | 12:03 PM
I have on a friend's car. It makes it easier to change filter, and makes less of a mess
Old Dec 23, 2012 | 12:08 PM
Vader99's Avatar
If it's cheap enough, I'd say get it. Just because it's on ebay doesn't make it a piece of crap. It is possible to buy big name band parts on eBay if it's that important.
Old Dec 23, 2012 | 12:11 PM
Vader99's Avatar
I'm betting you can find a good quality oil cooler cheaper than that.
Old Dec 23, 2012 | 06:56 PM
McNassty's Avatar
I don't really need the kit because my oil cooler is good I have a leak at the block where the oil cooler adaptor plate meets the block. They don't make these parts anymore so that is why I may end up buying that kit because it may solve my leak
Old Dec 29, 2012 | 04:18 PM
McNassty's Avatar
I found an assorted oil o-ring kit, now I just have to wait till Monday for my Royal Purple oil filter to get here from American Muscle than I'm going to see if I can fix the leak without buying the relocation kit
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
southern stang
Sep 26, 2015 04:19 PM
