Misfire
Old Mar 29, 2013 | 03:29 PM
alfredoGt's Avatar
Misfire
A few days ago i was driving home from work and the weather was pretty bad.The streets were filled with water and my car managed to somehow suck water inside the engine.From the intake i belive.Anyways,it started knoking loud and idk what could be wrong.My friends tuner reads misfire on culinder #8 what can i do to fix this knoking!
Old Mar 29, 2013 | 03:31 PM
alfredoGt's Avatar
Thats my oil before finishing the oil change
Old Mar 31, 2013 | 12:59 AM
bluethunderhorse's Avatar
Sounds and looks by the oil that the engine did suck in water, and hydrolocked. You most likely have a bent rod and shattered piston at the least. Seen in lots of times and that oil is a dead give a way. You're gonna have to have a complete engine rebuild, and probably some machine work on the block and heads
Old Mar 31, 2013 | 09:24 AM
alfredoGt's Avatar
Idea of how much $ it will cost me?
Old Mar 31, 2013 | 10:09 AM
Blackout's Avatar
I work at a machine shop so it'll be whatever they charge an hour and the job to do it. Like line bore, cylinder bore if necessary, surface grinding and the heads themselves three way valve job check the valve seats. I love working on the heads.
I recommend you rebuild it yourself and get the machine work just done by a pro
Old Mar 31, 2013 | 10:11 AM
Blackout's Avatar
Trust me its worth it. Get that book from Barnes and nobles
Old Mar 31, 2013 | 11:03 AM
Since the engine will need a rebuild you might as well go ahead, and forge the bottom end. That way you'll know that the engine will be able to handle anything you throw at it, be it a supercharger, turbo, or nitrous.
http://www.livernoismotorsports.com/...ssemblies.html
http://www.dssracing.com/4_6_SX_rota..._p/ra4.6sx.htm
Old Mar 31, 2013 | 11:07 AM
BRADGTCS's Avatar
before you go for a rebuild drain and replace the oil and see if it gets better. depending on the level of knocking if could have be ceasing from the lack of good lubrication. based on that year it may have been the rear driver side lifter and cam which gets the least amount of oil. If it goes away your lucky. I am sure some damage may have occurred but it may buy you some time for replacement costs.
Old Mar 31, 2013 | 11:22 AM
There are no lifters in that engine
Old Mar 31, 2013 | 11:34 AM
BRADGTCS's Avatar
Never had to open my 2003 up. They may not be the traditional pump up type lifter but there has to be some kind of transition from the cam to the spring. I am more old school engines and not completely up to date on the new engines as far as the strange changes or differences in nomenclature for some the internals. Just hoping to help save the guy some money in case he does not need an engine rebuild right now. My apologies if I mis spoke on this one.
Old Mar 31, 2013 | 11:43 AM
Blackout's Avatar
I think I read somewhere that you changed your oil, but I'd say donut again. When I ported and polished my intakes I didn't think about draining my coolant. So I was in big trouble after it sat up for a month and I restarted it. Luckily I changed the oil twice and now it's back to normal. It was a very hard start up. Almost didn't make it
Old Mar 31, 2013 | 12:03 PM
The DOHC 4.6 has what looks like roller rockers that follow the cams and press on the valves. Every single case of a car sucking in water from the CAI, I have seen results in a bent rod and either a cracked or shattered piston.
Old Apr 1, 2013 | 01:59 AM
alfredoGt's Avatar
I just looked at my paper work from the dealership where we got the cobra.Im glad to say that we paid some extra cash to cover any accidents or damage to the engine and transmission
alfredoGt's Avatar
So ill be taking it to their shop and see what they say
STOERKEL
Sep 11, 2015 11:38 AM
bconboy
Sep 10, 2015 02:31 PM
dakotawolfe
Aug 26, 2015 04:01 PM
Beavis9000
Aug 10, 2015 12:16 PM
db2797
Jul 28, 2015 07:34 PM
