A Little Tri-ax Trouble
Old Jan 3, 2005 | 11:40 PM
will's Avatar
I just installed my Steeda Tri-ax shifter in my '04 GT. Everything was well and good until I went to screw the shift ball back on. It's a full 180 degree turn from being straight (Instead of 1 in the top left, it's upside down "R"). The reason I asked Mach 1 owners to look is because my GT came with the silver Mach 1 shift ball. Did any of you run into this problem and is there a simple way to fix it?
Old Jan 3, 2005 | 11:53 PM
wild stray's Avatar
Try dropping something into the hole in the ball until it sets right for you.
I've used steel putty and let it set where you want it, then use loc-tite to secure the ball so it doesn't rotate out of order.
Old Jan 5, 2005 | 06:35 AM
REDFIRESNAKE's Avatar
So how does it shift now?
Old Jan 5, 2005 | 07:07 AM
will's Avatar
Wonderfully! It's notchier and much much shorter than the factory shifter.. no longer feels like I'm choking a rubber chicken when I shift. Now if I can just get that stupid ball on right...
Old Jan 6, 2005 | 05:49 AM
Evil_Capri's Avatar
I have a Tri-Ax, but I have a Hurst Stick, and T-Handle. Sorry I can't help, but I agree with 'wild stray'.
Old Jan 10, 2005 | 06:37 PM
Fordracing200's Avatar
Don't notchier shifts stink? I have heard they do but have never expierienced it.
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
mx5jhb
Sep 30, 2015 04:44 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
Airborne42
Sep 25, 2015 05:14 PM
Sep 16, 2015 06:44 PM
