Help. Turn signal problem
Old Jul 9, 2008 | 07:07 PM
BamaRon's Avatar
My son has a 2002 Mustang GT and has developed a problem with his turn signals and emergency flashers. When either of the turn signals are turned on, the lamps come on but don't flash, the similar thing happens when the emergency flasher is activated. All lamps light up but do not flash. My first guess is that the flasher is bad. The guy at Auto Zone felt it was also the flasher.
Do you agree that this should be the problem?
Second problem! Where is the flasher located on a 2002 Mustang?
Old Jul 10, 2008 | 09:55 AM
Knight's Avatar
Needs to be more Astony
Would prob be a relay. did you check them?
black box on the right there.
Old Jul 10, 2008 | 03:42 PM
GottaHaveIt's Avatar
if all the bulb are good then flasher plugs into fuse box or like Chris said relay
PonyMuscletang13
Sep 26, 2015 02:33 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
DrisStang
Sep 14, 2015 06:20 PM
Linkspure
Sep 12, 2015 06:33 PM
Sep 8, 2015 10:45 AM
