Heads? help
Old Apr 9, 2007 | 06:20 PM
kingC95GT's Avatar
Heads? help
I need a set of heads for my car. It doesn't make the power I want. I put a Ecam in it, now I need something to go good with that. What heads do you suggest? I want something for good racing, but still good on the streets.
Old Apr 10, 2007 | 07:31 AM
Knight's Avatar
Needs to be more Astony
AFR 165cc are prob the best ones to get for your setup.
You are going to want to upgrade your fuel system if you get heads. Those heads matched with those cams are going to flow way to much for 19lbs injectors. actually i noticed you don't have any intake or Throttle body mods listed. So you are going to ahve a bottleneck right there.
My 1990 had an e-cam also. Its running 24lb injectors. You seem to have a very similar setup to my old engine. But it had Holley heads. I don't remember which ones exactly. I didn't build the engine so i didn't have a choice in parts.
Old Apr 10, 2007 | 05:11 PM
kingC95GT's Avatar
yeah i need to get a different throttle body, but it comes with a 70 mass air and 24 lbs injectors. so would i need to go bigger,? i thought about porting my intake since it is a GT 40 intake. i planned on getting a new fuel pump and i guess a regulator. anything else?
Old Apr 10, 2007 | 08:52 PM
Knight's Avatar
I was going by what you have listed in your sig. it doesn't mention the intake or the 24lbs injectors. so thats why i say that.
24lbs are fine at this power level.
Yes i would recommend a 65mm throttlebody if you don't have one.
Old Apr 11, 2007 | 11:15 AM
kingC95GT's Avatar
yeah it comes stock with one. but do i need to go bigger
Old Apr 11, 2007 | 03:39 PM
Knight's Avatar
Oh sorry i forgot you are talking about a cobra... My car had heads, e303, 65mm tb, gt40 intake, 24lbs injectors...made around 350hp
You shouldn't need any bigger injectors or tb unless you went forced induction.
Old Apr 11, 2007 | 07:15 PM
kingC95GT's Avatar
Is there anything bad about the GT 40 Heads or Eldelbrock heads? and isnt my CC around 60 or 61cc.
Old Apr 11, 2007 | 11:01 PM
Knight's Avatar
sorry 165 is not the chamber size...they are 58cc. I think the edelbrocks are very comparable but both the edelbrock and the afrs are better then the gt40 heads.
Old Apr 11, 2007 | 11:13 PM
kingC95GT's Avatar
ok thanks.. i have been checking in the edelbrocks here lately. do you think 155 fuel pump would be over kill or just a 110 will do fine. i think stock is a 85 90.
NC14GT
Sep 10, 2017 04:47 PM
Sep 30, 2015 07:02 PM
FromZto5
Sep 30, 2015 05:28 AM
earl610
Sep 7, 2015 11:57 AM
