GT won't start without gas prime
Old Jan 18, 2015 | 02:58 PM
ford96gtconv's Avatar
]My car has been sitting for over year, have broken back and clutch was fubared. Finally swapped clutch and PP out works great, went back to a stock clutch.
Now charged battery for 2 days hit the key no start, squirt gas into CAI/throttle body and runs, will run untiil I turn off than won't restart. I swapped the throttle position sensor and the 3 wire plug, thought that was the problem wire were all exposed and rotten. Wehn the car does start with help(prime with gas) is runs but when I try to gas it falls on it's face.Fells like when you have CAI off, will idle will throttle up slowly, but if I punch it it stalls and than have to prime again.
Any ideas all of a sudden this is my son's only transportation.
I call this car Frankenstang, 01 Gt with a 02 Police Intercepter swap
Old Jan 18, 2015 | 04:40 PM
Jazzman442's Avatar
Not enough fuel getting to the engine. Is the fuel filter clogged? If you are using ethanol I bet it is. Also is the fuel pressure to the engine enough?
JT_Kwik
Nov 29, 2022 01:45 PM
Mpaps
Oct 11, 2017 08:06 PM
