could this be exhaust, electrical or fuel related
Old Jan 19, 2015 | 06:22 AM
mustanglu's Avatar
I have a 95 mustang 5.0,
.40 pistons, .10 crank, running old skool 2150 motorcraft 2bbl, New timing chain,New plugs,New fuel pump,New filter,New distributor... i recently installed 3in exhaust under it. It ran great for about 3 wks, now when i get up in the morning, crank it up,it runs, it idles, Oki go to the store (i learned to leave it running)i come back out to leave,turn key,just cranks no start. It will to sit at least 2hrs before i can restart it and sometimes it still won't start. I need help!
Old Jan 20, 2015 | 06:38 PM
kph03281983's Avatar
sounds like...
From the sounds of it... u might wanna check distributer. Lots of people seem to have same problem
Old Jan 21, 2015 | 05:05 AM
Is it electric choke? Do the butterflies close when you set the choke?
Does the accelerator pump spray fuel in the throat when you open the throttle?
Any vacuum leaks?
Fastnloud
Feb 15, 2016 05:21 PM
Sep 24, 2015 08:15 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
