Engine swap
Old Feb 15, 2013 | 12:32 AM
onequickstang's Avatar
Originally Posted by 97GT03SVT
I live in Massachusetts, like California we have very strict emissions I think you would have a hard time passing emissions with a carbureted motor. I think your best bet would be to buy a 1996-98 cobra as a good starting point. I've noticed these are getting affordable now. I understand sentimental value but at the end of the day living in California, this project seems very risky
Yes sadly I'm coming closer to my terms with my pocket book. When all is said and done I need it to pass smog but the 94 will be more of a nice car to drive once in a while. My whole plan with this car is:
-swap out for a 351
-swap auto tranny for manual
-look in to fabricating a hard top to replace the rag top
-cobra intake hood
-cobra front bumper (purely for the fog lights, I don't like the fog light setup it has)
-paint
-and last but not least interior
I actually started working at Ford as a porter my goal is to become a mechanic, and eventually get an 07 shelby and revisit my goal of 1000 hp to the wheels
Old Feb 15, 2013 | 12:38 AM
Originally Posted by 1999Pony
That could be a problem lol I have a cold air kit on my 5.0 as of now
Old Feb 15, 2013 | 12:40 AM
However back to topic at hand, is it at all possible to get a carbureted 351 to pass smog?
Old Feb 15, 2013 | 11:11 AM
1999Pony's Avatar
I looked around a little bit and it does appear to be possible. You would have to get it tuned each year to lean out the a/f ratio. I read something that it needs to be 14.7:1. That's not something you'd want to keep year round, so each year before you go to get it tested you'd need to tune it.
You would also need any emissions equipment that came from the factory on the car as well.
Old Feb 15, 2013 | 11:19 AM
Ok. So if I keep the cats on it should be good? As long as I tune it properly each year that is
Old Feb 15, 2013 | 11:29 AM
1999Pony's Avatar
Yep, cats, egr as well if you have one and get it tuned.
Old Feb 15, 2013 | 02:32 PM
97GT03SVT's Avatar
-swap out for a 351
-cobra intake hood
-paint
Please don't take this the wrong way but I suggest you just buy a car closer to your needs. The combination of a 351 carbed swap, manual transmission swap, hardtop fabrication, cobra bumper + Hood, then getting the thing to pass smog emissions is a tall order. I'd say you would be better suited selling your current ride and buying a 1996-98 cobra or even a 1999-04 gt.
Old Feb 15, 2013 | 02:51 PM
SVTCobraR315's Avatar
find a friend in florida and register it there. No emissions here
i blew my cats out into my mufflers not long ago. so i just gutted the rest out. all good :P
Old Feb 16, 2013 | 10:53 AM
bluethunderhorse's Avatar
There's a lot more than than that. The first thing they do is a visual check. Cats, egr, evap system, lines, hoses. If anything is missing or disconnected it fails before they do the sniffer test. If the car came with fuel injection, and it has a carb on it it will fail the visual test. In Cali when you do an engine swap, for it to pass the visual the swapped engine has to have been an option from the factory. You can swap to a newer engine, but all emission related equipment from that engine has to be swapped in also. The Cali air resource board does not allow an older what they consider dirtier engine to be swapped, unless the car is being used for off road only. They even limit what type of performance parts can be added to the cars, hence the C.A.R.B. approval stickers on a lot of aftermarket parts. Your best bet for more power would be to either, rebuild the 302 and supercharge it, or sell it and get a Cobra, or a modded GT
Old Feb 16, 2013 | 07:53 PM
Ok I think I'm gonna have to do that then. Tank you
Road_Runner
Sep 2, 2024 04:46 PM
trackpack13gt
Oct 2, 2015 08:20 PM
Ray11
Sep 25, 2015 12:43 PM
