Clutch cable
Old Mar 29, 2012 | 02:08 PM
Dbranham's Avatar
Clutch cable
How do I adjust my stock cable? Should I replace it? Is it a do it yourselfer have a shop replace?
Old Mar 30, 2012 | 07:27 PM
skunk21's Avatar
Here is a link from the Fox section. I posted a "how to" for a member with pics on a clutch cable install and adjust very easy. It will be pretty much the same for your car has the fox, we are pretty much the same thru '04.
https://themustangsource.com/f634/cl...-stang-504508/
Old Mar 30, 2012 | 10:19 PM
Dbranham's Avatar
Thanks! I figured out how to adjust the cable underneath the dash. Some of the teeth were worn down so it wouldn't keep it's adjustment. Well I dropped the car off at the shop and will be pick it back up when I come back in town.
Old Apr 1, 2012 | 08:01 PM
Ddejesus523's Avatar
I had the same problem. They're going to tell you that you need a clutch quadrant and new cable. If they let you order parts UPR performance has the quadrant, cable, and firewall bushing for $79.99
Old Apr 1, 2012 | 08:56 PM
Dbranham's Avatar
Yeah. I knew I needed those and was going to do it myself but I'm leaving for vacation and would like it to be ready when I'm back. Oh well, the shop loves me, I'm their regular..
Old Apr 2, 2012 | 06:57 AM
skunk21's Avatar
IMHO stay away from the upr quad. there are much better quads than the upr one. again just my opinion, if you use the upr quad don't use the top hook, and tehy have one of the cheapest cable out there.
Old Apr 2, 2012 | 07:12 AM
Should I return it and get the steeda one? It was $25 more at 104.99
Old Apr 2, 2012 | 07:20 AM
skunk21's Avatar
I would run a steeda or Maximum motorsports setup.
http://www.maximummotorsports.com/st...8a1e5d6dfc98cc
The stock oem clutch cable is the best ( if you can swing it) cable for our mustangs. Most after market cables tend to stretch and creak for some reason vs the stock cable. One of the best set ups out there that many guys I know run is a Ford cable, Maximum motors quad and Fiore fire wall adjuster ( probally one of the best on the market).
http://www.lethalperformance.com/03-...juster-p-10365
I run the maximum quad kit, love it and have had it for a few years now and it been flawless. I know a few people with the steeda set up and they aren't bad either. UPR
Old Apr 2, 2012 | 09:41 AM
1999Pony's Avatar
Run the maximum motorsports. I've had both, just replaced the steeda after it wore out. I had the steeda for about 3 years before it stretched. MM uses a OEM cable which will give you the longest life.
Old Apr 15, 2012 | 10:21 PM
Thanks fellas I ended up running the maximum motorsports setup
Old Apr 16, 2012 | 06:34 AM
1999Pony's Avatar
Good call
Gill5oh
Oct 6, 2017 10:50 PM
Sep 23, 2015 03:21 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
1001yos
Sep 8, 2015 10:05 PM
