Can anyone tell me what this means?
I recently found out about the little secret when you hold down your trip button and get all of the different gauges. This one says oil but it reads 000 while the car is running. Can someone tell me what this means?
OIL - Displays the code (0-250) for the oil pressure switch input to the HEC. Oil pressure gauge will indicate present oil pressure. Normal oil pressure (greater than 6psi) will display a value between 000 and 176. A low oil pressure or an inoperative engine oil pressure switch (less than 6 psi) will display a value greater than 176.
