big wheels
I've seen 17x10.5" on the back of a sn95 with not really any problems. Thats running 315 series tires. It may be a problem rubbing against the quad shock, but you can reverse it to get some more clearence.
You can go wider I believe. 18x9 up front is about the largest you can go, tire sizes I would think would be in the 265 range. The back you can probably run a 18x10.5" rim with 315 or maybe 325 tires. Not sure, i would consult whoever you are getting tires/rims through.
MRGTX
Sep 16, 2015 08:08 AM
