abs light is on
Old Nov 17, 2005 | 12:26 AM
mstng351's Avatar
Thumbs down
my abs light just came on and was wondering if this is a normal thing for my year? the previous owner gave me the abs pump from a 95 cobra, so if it is that, i could install it. i was also wondering if i took my car to autozone, would they be able to tell if it's the computer or not? thanks in advance.
Old Nov 17, 2005 | 08:08 AM
JeffreyDJ's Avatar
Could be a sensor or loose hose. I had that on my Mach when it was new.
Old Dec 5, 2005 | 10:32 AM
joker's Avatar
If your brakes are still stopping perfectly normal, I would bet on it being a sensor. From my understanding when the pump goes out your brake pedal will get VERY stiff.
Old Dec 5, 2005 | 12:22 PM
HastaLaVista's Avatar
If it's anything like other Ford passenger cars of those years - sure someone will correct if wrong - there's a notched ring on the inner part wheel that can slip off.
I had this happen and went under the car and slipped it back on. Kept falling off so I got hi temp silicone, gooped a little on there, slipped it on again. Stayed fine until I got rid of the car years later.
Old Dec 14, 2005 | 08:05 PM
DanS.02GT's Avatar
What you're talking about is called an exciter ring, and it's not uncommon to see them crack.
Old Dec 19, 2005 | 03:27 PM
FLAstangx3's Avatar
AH HA! Goosed it with the Traction Control still on, did ya. I did, blew right front wheel sensor. Your brakes will be okay, just not abs working. Easy, painless fix.
Old Dec 19, 2005 | 03:45 PM
Scothew's Avatar
Stubborn Bear
TMS Staff
I dont think that is the problem since I do not believe any 94 mustang came with traction control. That was introduced in '99 on 5-speed models and 01 on all models (auto and 5-speed).
Old Dec 21, 2005 | 12:18 AM
joker's Avatar
You are correct Sir, there was no traction control available until 99
Old Dec 22, 2005 | 03:18 AM
jgsmuzzy's Avatar
Although slightly wrong, it was introduced on Autos in 2000, I know this for a fact, cos mine has it
Old Dec 22, 2005 | 06:52 AM
Scothew's Avatar
Stubborn Bear
TMS Staff
My 00 GT automatic did not have T/C.
Old Dec 22, 2005 | 07:06 AM
conv_stang's Avatar
i believe it was an option starting in 99. if you got ABS as an option you could get traction control. in 01 they made ABS standard on GT's so most came with traction control. my wife's 00 V6 w/ auto had abs and traction control
Old Dec 25, 2005 | 08:24 AM
Want2GoFaster's Avatar
I had the abs light come on last month. The brakes feel fine. Any more detail as to the exact locaion of this exiter ring?
Thanks in advance
Old Jan 23, 2006 | 11:15 AM
stoic21's Avatar
I am also interested in this. I have a 96gt and mine will go on and off. It's kinda funny. When I go forward it goes off, when I slow down it goes on. Where is the sensor?
Old Jan 26, 2006 | 09:13 PM
stoic21's Avatar
anyone? I can't find it in the guide.
Old Feb 13, 2006 | 07:12 PM
Skorch52's Avatar
My ABS light came when I had larger diameter tires on the back (245/45 front, 255/50 rear). Doesn't sound like this is your problem, but thought I would throw it out there.
RCooke08GT
Feb 19, 2017 03:03 AM
boz
Oct 1, 2015 04:47 PM
mmb0329
Oct 1, 2015 10:59 AM
Fedupdave42169
Sep 30, 2015 08:45 PM
