94 gt idling at high RPM
Old Mar 23, 2023 | 06:09 PM
EZ1958's Avatar
Started my 94 5.0 up after eating lunch ang it was idling at 2750 RPM. I looked at the thing's like throttle linkage ect and can not figure what else to look at. I installed a new map sensor but still idles very high. Recommended fix's???
Old Mar 23, 2023 | 06:26 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
Is the blade in the throttle body opening and closing completely?
Old Mar 23, 2023 | 06:42 PM
EZ1958's Avatar
everything is opening and closing as it should.
Old Mar 23, 2023 | 07:09 PM
Like Father...
I ♥ Sausage
Next thing I can think of is throttle position sensor or maybe a vacuum leak.
Old Mar 23, 2023 | 08:43 PM
05stangkc's Avatar
Might Clean or Replace Idle Air Valve. When it Sticks it Will Cause Idle Issues. If It Sticks Again in the Meantime Tap it With Hammer Not Too Hard Now & See if Idle Drops. If it Does You Hit the Nail on the Head! If Not Still Deserves Some Attention!
https://oards.com/symptoms-of-a-bad-...control-valve/
https://www.rockauto.com/en/moreinfo...pd3SXAHQwgdwzG
Other Idea's If you Scroll Down as Well!
Kc
Cody Garton
Mar 22, 2019 10:12 PM
usaf1965
1994-2004 V-8
Jun 9, 2016 07:32 PM
Jakebnhm
1994-2004 V-6
Sep 17, 2012 09:06 PM
White5L
Feb 29, 2012 07:50 AM
GAGT
Aug 4, 2010 06:10 AM
