High Idle - Please help guys.
The past two or three weeks when I have got into my car after work the car idles at 2500 - 3000 rpms for about 5 - 7 minutes and then it goes back to normal idle. I have checked the trouble codes and it doesn't have any. Does anyone have any idea of what could be causing this and how to fix it?
I just put a throttle position sensor on my car because of it pulling codes and going into failsafe mode quite a bit. if you have a stock TPS sensor that may be the cause, because I read that irratic idle quality is also a factor if your TPS sensor is bad.
Sam
Sam
Clean your throttle body.
https://themustangsource.com/f669/br...e-body-481491/
