tires
Old Apr 22, 2013 | 03:30 PM
gardy004's Avatar
tires
What would be the best combination to use in a 98 mustang gt for tires? I want big tires in the rear and smaller in the front. This is the one that came with 245-45-17 I believe is 17*8 rims. I know that height could be a problem if I have different tires so that's why my question.
Old Apr 23, 2013 | 07:28 AM
welcome to TMS! Do you plan on changing out your rims any time soon? Do you need tires right now? You can do 275-40-17 in the rear and do the 245-45-17 in the front
Do know if this link will work.
http://www.discounttire.com/dtcs/tir...T%7Cpc%7C60441
But it will show you several different combos. Then use the tire calculator at the bottom of the page to see what the different numbers will get you
Old Apr 23, 2013 | 08:33 AM
gardy004's Avatar
Glen thanks for the reply. I do plan to keep the original rims. I like them and I want to keep it stock. Does 275-40-17 same height than 245-45-17?
Nevermind. I saw the calculator and gives me the info I need. Thanks a lot!!!
Old Apr 23, 2013 | 12:35 PM
Is it the same or close to the same height? I didn't check.
Old Apr 24, 2013 | 06:07 AM
1999Pony's Avatar
I think a 275 is going to be a little big for a 8in rim. I personally wouldnt go bigger then a 255. The 275s will buldge a whole lot on a 8in and will wear unevenly.
Old May 5, 2013 | 07:23 AM
gardy004's Avatar
Glen it is very close (the eye won't see a difference). I will dig in more info to see if the 275 could be an option since 1999pony could be right on the uneven wear
Old May 5, 2013 | 11:00 AM
1999Pony's Avatar
Its like putting 315s on a 9in wheel. Can it be done and should it be done are two totally different answers.
Rando
Aug 25, 2021 11:12 AM
cozyp828
Apr 18, 2016 09:46 PM
