Problem with check engine light and strange engine noise
Old Aug 2, 2022 | 02:49 PM
Smanly's Avatar
I have a 2000 Ford Mustang 3.8L V6 and I am having problems with it. I get a check engine light on when it runs for a long period of time and don't know why. I get engine running too lean codes on it. The obd II sensor says the sensors from all systems are ok, and I just changed the fuel filter. Also, when the engine is warmed up all the way, when idle, it first starts squeaking then it starts whining and wailing. When I turn off the engine, I hear what sounds like air escaping, but not sure. Can anyone help me? I love my mustang and hope it's not something too serious.
Old Aug 2, 2022 | 03:19 PM
05stangkc's Avatar
Hello,
What Exact Codes are You Getting? Does your reader Check Fuel Trims?
The Whining & Wailing Sounds Like Air Bypass Valve. It Controls Idle Speed. You Also may have a Vacuum Leak & Need to Check all Vacuum Hoses to Start. Get a Helper under the Hood at Shut Off & Try & Pin Down Sound. Shut Off Sound Could Be A/C System if you are Using It Currently. It's All Process of Elimination.
KC
Air Bypass Pic For You! By Throttle Body.
Old Aug 2, 2022 | 04:00 PM
Smanly's Avatar
Hello,
KC
I am getting either a P0171 or a P0174 or sometimes both. They usually only come on when the car has been run for a while after warming up all the way. Could the air bypass valve also cause this? The whining only happens when the car warms up completely. A/C system I don't use.
Old Aug 2, 2022 | 04:20 PM
05stangkc's Avatar
Here is a Good You Tube on Finding A Vacuum Leak Using a Spray Bottle. Some Use Flammable Sprays & I am NOT going to Advise that!
When the Car is Cold it is in Rich Mode Per Say and Once it Warms Up Then the Lean Issue gets Compounded. I had the Same Codes on my 02 Harley F150 Supercharged and Chased it a couple of Times!
First time it was a Bad PCV Line which on the Harley Truck you got to pull the Blower to replace. Fixed it For awhile until the next Time Then it Turned out to be a Leak Between the Exhaust Manifold & Head Pipe which you could only Hear Going Down a Narrow Road with tall buildings on both sides so you could hear the Echo. A PIT PIT PIT Sound. Exhaust Leaks Reek Havoc on the 02'sensors.
Fords Are notorious also for the Vacuum Lines turning to Mush. You Grab Certain Ones and they Turn to Goo! Had to Replace the EGR Transducer Lines for what would have been a Vacuum Leak. If you grab a Vacuum Line and You hands are covered in a Sooty mess those lines need attention.
The Whining Wailing I have heard over the Years when an Air Bypass Goes Bad, But Unsure if a Failed one would Throw Lean Codes. You Should be able to Feel the Valve Pulsate When The Noise Occurs if it has Issues. Failed Air Bypass would Likely Give Poor Idling Too High, Too Low or Surging.
I was in Ford Dealership Parts for 35+ Years & have Picked up some Knowledge but I'm no Line Tech I Just Worked & Learned from Them, I always advise Checking things out First vs Just throwing Parts at it as Some Do.
Hope this gives you a starting point!
KC
Old Aug 5, 2022 | 08:08 PM
Smanly's Avatar
Ok, I just cleaned the IAC and saw that the gasket fell apart. Just made a new one, but I am going to replace the IAC. It was filthy.
Old Aug 6, 2022 | 11:19 AM
05stangkc's Avatar
Sounds Promising!
KC
Old Aug 6, 2022 | 01:32 PM
Smanly's Avatar
Nope. Cleaning it didn't do much about the noise, but the check engine light hasn't come on yet. I ordered a new IAC part, so I'll see if I can do something about that. Also, the inside has what looks like black sludge. What do you recommend to clean it out with?
Old Aug 6, 2022 | 02:24 PM
SpectreH's Avatar
I’d consider cleaning the throttle body as well.
Old Aug 6, 2022 | 02:29 PM
Smanly's Avatar
Should I just use a rag to clean the black sludge inside the engine where the throttle body and IAC are attached? Or is there something you can recommend?
Old Aug 6, 2022 | 03:00 PM
05stangkc's Avatar
A Good Spray Throttle Body Cleaner Use a Namebrand Like CRC Etc. Don't Use Quote Carb Only Cleaner. Should Specify T/b or T/b and Carb. If you Clean Off Vehicle Get The Gaskets You Will Need Before Hand.
This Video Seems Pretty Good!
KC
Old Aug 10, 2022 | 02:38 PM
Smanly's Avatar
Just replaced a vacuum hose. It was very worn. Now the codes are just pending. Could a malfunctioning MAF sensor cause it too?
Old Aug 10, 2022 | 05:01 PM
m05fastbackGT's Avatar
If the MAF sensor has a malfunction, it most definitely is a contributing factor... First step, is use CRC MAF sensor cleaner... If this doesn't help resolve your issue, then I would look into replacing the MAF sensor...
https://www.autozone.com/miscellaneo...B&gclsrc=aw.ds
Old Aug 22, 2022 | 03:23 PM
Smanly's Avatar
I just checked the live feed on my obd II. Long term fuel trim is higher than it should be. Does that mean it could be a bad oxygen sensor?
Old Aug 22, 2022 | 05:41 PM
Check the code for long term fuel trim on google.. The description will say whether it's related to a faulty 02 sensor, or if it's related to something else
Old Aug 22, 2022 | 09:53 PM
05stangkc's Avatar
https://www.obd-codes.com/faq/fuel-trims.php
Kc
Old Oct 16, 2022 | 09:39 PM
Smanly's Avatar
It was my O2 sensors. The 2 on my engine went, and the two on my converters were trying to compensate. When I got them replaced, the mechanic didn't burn off the stuff that they put on. That also sometimes trips the check engine light. Do I have to just keep driving until I burn it off?
Old Oct 17, 2022 | 01:54 PM
05stangkc's Avatar
I would Pull it and Spray It Down with an 02 Friendly Cleaner! Check Wiring Carefully as Well While you are At It! New Parts Can Be Bad out of the Box as Well.
KC
Old Oct 17, 2022 | 03:55 PM
What He Said!
jonser
Ecoboost
Jun 28, 2016 01:53 PM
Zastava_101
Jan 13, 2012 04:48 PM
firestang70
Feb 11, 2008 09:04 PM
gshub77
Oct 5, 2005 02:52 PM
flight96
V6 Performance Mods
Mar 20, 2005 04:33 PM
