Service Engine Soon
Old Dec 29, 2011 | 07:31 AM
Zastava_101's Avatar
TMS Post # 1,000,000
Serbian Steamer
Service Engine Soon
This morning on my way to work a "Service Engine Soon" light came on on my Mustang.
Does that mean that a tuneup needs to be done or is it something else?
2000 Mustang V6 5-speed, 63,000 miles.
Old Dec 29, 2011 | 07:47 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
That's the same thing as a check engine light. Run the codes buddy.
Old Dec 29, 2011 | 08:04 AM
Serbian Steamer
Crap ... that's the last think I needed right now ...
Old Dec 29, 2011 | 08:08 AM
Bear Eats King...
Bear ****s Bone
Run the codes. I can probably guide you through the repair. Autozone reads codes for free.
Old Dec 29, 2011 | 09:05 AM
Serbian Steamer
Thanks for your help.
Old Jan 6, 2012 | 02:44 PM
Serbian Steamer
Took it to the Auto Zone over the weekend. It turns out that a fuel hose has a leak somewhere ...
Old Jan 6, 2012 | 02:51 PM
UnrealFord's Avatar
Was it a EVAP code? Check or replace gas cap,
Old Jan 6, 2012 | 02:52 PM
Bear Eats King...
Bear ****s Bone
That's weird... that don't usually set a code...did you mean evap fuel vapor line?
Old Jan 8, 2012 | 06:44 AM
Pete07GT's Avatar
Originally Posted by texastboneking
that doesn't usually set a code...
Updated from redneck speak.
Old Jan 8, 2012 | 07:19 AM
phiggs54's Avatar
that usually doesn't throw a code..
updated to track rat speak
Old Jan 8, 2012 | 07:21 AM
AlsCobra's Avatar
A Man Just Needs Some....
.. that don't throw no code
updated again to Nola specs.
Old Jan 8, 2012 | 08:52 AM
Bear Eats King...
Bear ****s Bone
Nig** that sh*** don't throw that dam check engine light. Kno wat I sayin,?
Old Jan 8, 2012 | 09:05 AM
phiggs54's Avatar
A lot of useful information here
Old Jan 8, 2012 | 09:08 AM
Bear Eats King...
Bear ****s Bone
Lotta good info on dis here thread mane.
Old Jan 8, 2012 | 09:59 AM
gas cap??
Old Jan 8, 2012 | 04:44 PM
Pete07GT's Avatar
Bone; proof that you don't need above a "speshul" IQ to work on cars..
Old Jan 8, 2012 | 04:49 PM
Bear Eats King...
Bear ****s Bone
Exactly!
Old Jan 8, 2012 | 07:04 PM
01GT's Avatar
whats the code? Could be one thing or than one. Depends on the code and if more than one code, than the order the codes. Pull OBDII codes all day long.
Old Jan 8, 2012 | 07:08 PM
01GT's Avatar
Gas cap, vapor canister, purge valve solenoid, hoses to vapor canister could be loose, off, cracked.
Old Jan 9, 2012 | 12:08 PM
benjyc32's Avatar
You probably just have a vacuum problem because of the leak. Should be too $$ to repare, just a hassle to actually locate the leak. But nothing a couple dollars worth of tube couldnt fix.
