oil question
Old Sep 1, 2006 | 10:25 AM
knucklehead_11's Avatar
oil question
Using synthetic oil (Mobil 1 5W20 specifically), how many miles can a Motorcraft filter hold up until, or would you guys recommend spending a few extra bucks on a good aftermarket filter to hold up longer?
Old Sep 1, 2006 | 12:18 PM
mudshuvel319's Avatar
i use mobil 1 and a fram. i spend $20-25 for the oil and filter and I usually go about 5000 miles between changes. I know they are both rated for 8000-10000 miles, but I play it really safe.
Old Sep 6, 2006 | 08:48 AM
Okay, one thing I definately know for sure from this story that I hope you know:
Fram = sh1tty filters
Okay, so I can last a while with the Motorcraft apparently. I know it's definately no junk filter considering it's the same as a Purolator. But yeah. Thanks.
Old Sep 6, 2006 | 10:41 AM
theedge67's Avatar
Spend a few extra $$ and get a Mobil1 Synthetic filter. Much MUCH better than conventional paper filters.
Old Sep 6, 2006 | 11:25 AM
OKCMustangGT's Avatar
Mobil1 Oil & Mobil1 Filter.
Old Sep 7, 2006 | 11:24 PM
Sounds good to me. How many mile interval can I go up to with that?
Old Sep 7, 2006 | 11:26 PM
FireFighterHill's Avatar
I use the K&N Filter and mobil one synthetic oil, where do you guys get your Mobil One filter? Do you think its better then the K&N?
Old Sep 7, 2006 | 11:28 PM
5,000 miles and keep the reciepts and write the mileage on the reciept. If you go more could cause warranty problems down the road. Alot of guys here are only going 3,000 between changes.
Old Sep 11, 2006 | 01:55 PM
Pony Ride's Avatar
On synthetic????? $$$ down the drain......
Old Sep 12, 2006 | 12:25 AM
Yeah that's what I thought. I figure probably about an 8000 mile interval at least. I just wanted to see what you guys thought too.
Old Sep 12, 2006 | 03:09 AM
Im still going to change mine at 5,000 I put the synthetic in for better/uniform protection. I drive mine hard and going to work it doesnt have time to warm up completly which is harder on the engine.
MustangConvert11
Sep 30, 2015 08:01 PM
southern stang
Sep 26, 2015 04:19 PM
