Mach460 problems
Old Aug 30, 2004 | 07:57 PM
JaredG's Avatar
Ok, my cd player started screwing up a couple days ago, there are 5 cd's in it right now, it won't eject any, it won't play any, etc etc. Whenever I hit any button that has to do w/ the cd player, it tries to do whatever I told it to, but then always says "CD Error". Anyone know what could be the deal? Also, on the LCD, above where the cd's say disk 1 2 3 4 5 6, the letters "ST" are between 4 and 5. Maybe this means it's stuck between slot 4 and 5? Any help would be much appreciated!
Old Aug 30, 2004 | 08:25 PM
pilot1129's Avatar
happens to mine all the time. try loading and ejecting the cd and use a key to push the cd thats in there back in. it works easily when i do it.
Old Aug 31, 2004 | 09:39 AM
JaredG's Avatar
well, I doubt that will help. The cd door doesn't even open when I hit "Load cd (insert number here)".
Old Aug 31, 2004 | 09:42 AM
pilot1129's Avatar
hmm, dunno in that case. my door atleast opens. take it to a local dealer?
Old Aug 31, 2004 | 11:17 AM
conv_stang's Avatar
can you unload a cd from any other slot???
Old Aug 31, 2004 | 04:41 PM
JaredG's Avatar
Nope. It won't do anything. I put my ear up to it and hit the Load button, and then the eject button after a minute, and it doesn't sound like it's moving or anything. stinks.
Old Sep 2, 2004 | 04:42 PM
JaredG's Avatar
ok, nevermind the "ST" that shows up, that's just on when it's on the FM radio (maybe it's "station" or something). The letters "TP" are above the 6th cd on the LCD, if that means anything.
Old Sep 2, 2004 | 07:11 PM
Boomer's Avatar
Had a similar problem..
IS the CD door open constantly? and can you see a CD trying to be unloaded?
try to use another cd or tweasers to get the stuck CD out...once that happens, the rest should reseat....
This reason in peticular is why I ALWAYS use burned CDs now.
If they are trashed, I still have the originals
Old Sep 2, 2004 | 10:43 PM
38special's Avatar
Had the exact problem with mine. The eject stops short of a successfull eject. An unfolded paper clip with a slight hook, inserted sidwise and when it should be at the hole in the cd a twist to hook the cd and pull it out.
I found that if I restarted the car that the unit might function and pop it out on its own.
I have not had this problem in some time, but I keep the paper clip just in case.
Old Sep 3, 2004 | 11:30 AM
JaredG's Avatar
Boomer-No, the cd door won't open @ all. 38special- I'll try that and get back to ya'll. Thanks everyone for the help so far.
Old Sep 3, 2004 | 01:13 PM
JaredG's Avatar
paper clip didn't work. Guess I'll just take it into some cd repair store.
Old Sep 3, 2004 | 02:13 PM
Andy Haynes's Avatar
I didnt have the multi cd player but mine did this all of the time. I always took a cd and pushed it in like half way and hit the eject button it would pop the other one right out.
Old Sep 14, 2004 | 10:22 PM
Ballz's Avatar
Mine has always had problems. Normally it just won't eject and I have to use another cd to edge it out. It's become so constant that I always have a crap cdr ready to use as a tool.
I just started having this same problem last week. I tried to go from cd 2 to 3 and the cd player stopped working. I hit eject and got the same error. I turned the car off and back on and still nothing. It wouldn't play, eject or any thing. Then an hour later, after I'd gotten to where I was, I came back out and the cd started playing. It's been fine ever since. Just an odd bug in it I guess.
Old Sep 15, 2004 | 09:02 AM
Amy V6's Avatar
Boomer is win (almost didn't know who it was with the new avator and all... reminds me I need to change mine)
I only use CDR's from now on... incase they get stuck and I ruin it trying to get it out. Using a credit card works too.
And some people have said that the reason they get stuck in there is because it gets to hot in there... and some blame it on CDR's too. Oh and I know this one is true... never use those sticker labeling things that you print off your computer and stick 'em on the CD's.. those ALWAYS get stuck.
Old Sep 15, 2004 | 07:38 PM
JaredG's Avatar
Yea, I took it to the shop that specializes in Ford stuff around here, $330 to replace it! I think I might just get an iPod setup for it instead, for about the same price, since so many people seem to have had problems with these cd players.
Old Oct 26, 2004 | 03:06 PM
blaizedup's Avatar
EBAY . Anything that I need to replace on my car that I dont want to pay an outrageous price for, I get on ebay. Last stang I had, the amps were screwed. I went to ford and they said that one single amp was 300 (i think). I got both the rear amps and the one in the middle of the dash for $50
Old Oct 26, 2004 | 04:00 PM
1 COBRA's Avatar
Try disconnecting the battery cables, turn the ignition key on for a couple of minutes, take the key out, then connect the battery cables back. Have a credit card or something similar ready, press the eject button and if the CD slot opens, use the credit card (between the top of the CD and the upper portion of the slot) to guide the CD out. This process has worked for me. Best of luck.
Old Nov 1, 2004 | 11:11 AM
rm2000's Avatar
[quote]Originally posted by Amy V6@September 15, 2004, 9:05 AM
[QUOTE=Boomer,September 2, 2004, 9:14 PM] Oh and I know this one is true... never use those sticker labeling things that you print off your computer and stick 'em on the CD's.. those ALWAYS get stuck.
Haha...that is the truth!
Old Nov 3, 2004 | 02:10 PM
Nathan_H's Avatar
i know in my stereo, if it gets stuck, i can just hold eject and power at the same time, it then resets the player, and ejects all cd's. Don't know if it will help, but dont pay 300 some odd dollars for a ford stereo, go with an aftermarket.
Rando
Aug 25, 2021 11:12 AM
Mpaps
Oct 11, 2017 08:06 PM
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
