5.0 in 98
Old Nov 15, 2010 | 04:40 PM
Overtheft's Avatar
5.0 in 98
If I decided to take out my 3.8 and put in a 5.0, what year should i use??? where would i find that engine at... actually where would i find good prices and engines for my year anywanys..
Old Nov 15, 2010 | 06:10 PM
harristotle's Avatar
A 5.0 out of an 87-92 Fox would get you forged pistons from the factory, the 93's had hypereutectic pistons. You could try a junk yard or look for someone who is parting one of them out.
Old Nov 16, 2010 | 05:42 AM
would the 4.6 fit in there as well?
Old Nov 16, 2010 | 11:38 AM
Overtheft's Avatar
yeah but i want to put a 5.0 want the full power
Old Nov 16, 2010 | 05:08 PM
225hp 300tq??
Old Nov 16, 2010 | 06:25 PM
I don't blame you. The 5.0 is a simpler engine to work on (ie 1 camshaft instead of 2 or 4), plus mods aren't terribly expensive for them. My best friend had a 5.0 Cobra... man that thing was sick. It's the reason I ended up buying my Cobra, although I opted for the newer 4.6.
Old Nov 17, 2010 | 02:02 AM
cntchds's Avatar
I'm sorry, but after jumping ship from my old 5.0 into a 4.6 I don't understand the want for the old pushrod anymore. Yes, it's easier to mod, but you can dump almost a grand in engine mods (like me...) and still have less power than a stock 4.6. Given that the 4.6 I have is a PI motor, unlike the 96-98 variants, but regardless. I've been turned to the mod motor side, and I am not looking back.
If I were you I would look for a motor out of a 96 Explorer. The motor should be perfect since it will come with GT40 heads and intake, so you will be at the top end of what the stock 302 would produce. Also it comes with OBDII which should make it much easier to tie into your gauges. Another thing you may need to worry about is the transmission. I don't know what the 3.8's used, but the 94-95 GT T-5s used a mechanical speedometer gear, while later ones I believe used an electronic speed sensor.
Old Nov 17, 2010 | 07:59 AM
The 96-98's use a mechanical speedo as well, however it's a different transmission with the T-45 instead of the T-5.
Old Nov 18, 2010 | 03:24 AM
cntchds's Avatar
I'm talking about the V6 which used the T-5 until '10.
Edit: http://www.ehow.com/facts_6875929_20...formation.html , I thought they stopped in 04, but I guess the T-5 was only just decommissioned.
Old Nov 18, 2010 | 06:05 AM
lowblustang00's Avatar
for v6s they switched the t5 over to an electronic speedo in either 98 or 99 can't remember.
probably 99'
Road_Runner
Sep 2, 2024 04:46 PM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Bryanh24
Sep 16, 2015 08:31 PM
Cdvision
Sep 5, 2015 05:22 PM
