transmission/idle problems
Old May 2, 2005 | 11:01 AM
Aikenstang88's Avatar
I bought an 88 5.0 a few months ago and I rebuilt the engine it it. It shifts fine in all the gears except 3rd. It grinds some everytime before going into gear. I think that the syncro has gone bad and was going to drop the transmission and replace them. I am wondering if it is worth me doing it myself or if I should get someone else to do. And if there was a kit or something that I would have to buy, and where a good place to look at getting one would be. How hard of a job would it be to rebuild my transmission?
My car is idling rough and stuttered the last time I drove it. I think that my timing might be a little off or the spark plugs may not be gapped right. Any ideas of what it could be would help me out a lot.
Old May 4, 2005 | 03:11 PM
Fordracing200's Avatar
is it your clutch?
Old May 4, 2005 | 06:37 PM
Coupe's Avatar
HERE is some info on T5s.
Also try HERE for a pdf version of a rebuild manual.
Only YOU know your abilities. How hard of a job it (rebuilding)would be, depends on you and what you think of your abilities. Go for it.
Since it only happens when going into 3rd, it's probably NOT a clutch issue.
TRY HERE for some diagnosis/possibilities. If it happens in "gears clashing" (read plural) clutch would then be ONE primary suspect first, but "other" problems would be present also.
Hope this helps. :scratch:
Old May 11, 2005 | 09:21 AM
conv_stang's Avatar
idles problem sounds it might be a vaccuum hose lose. check all connections to make sure everything was hooked up right. ifso then try timing and check the plugs and wires. good luck
Rando
Aug 25, 2021 11:12 AM
Mpaps
Oct 11, 2017 08:06 PM
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
