T5 Fluid
Old Jun 10, 2012 | 03:03 PM
madstyle1's Avatar
T5 Fluid
Is it possible for transmission to whine if the incorrect fluid was put in the T5?
I put royal purple synchro max in there and from what I understand Im suppose to put Dexron / Mercon III ATF. thanks.
Old Jun 10, 2012 | 05:03 PM
onebadvert's Avatar
im not sure but likely the TOB
Old Jun 12, 2012 | 06:13 AM
skunk21's Avatar
The T5 uses ATF and uses Dexron III like you stated. I know that RP states you can use it but I would run a high quality ATF which is totally fine for the tranny has a 1step but I also suspect you may have other issues.
Old Jun 12, 2012 | 12:47 PM
onebadvert's Avatar
If its a non w/c I believe it takes gear oil over atf.
Old Jun 12, 2012 | 12:59 PM
skunk21's Avatar
The only reason the non- wc takes straight 50W now is because dextron II is no longer available and it was a thick formula ATF. The non -wc originally used dextron II ATF, you can use ATF in the non -wc but there would be increased wear. This is due to there being no bearing under each gear and the bronze synchro rings. The WC was used by Ford in 1985 in mustangs, fairmonts, etc both V8 and 4cyls, older stuff had the non -wc so running across them isn't has common.
Old Jun 12, 2012 | 01:04 PM
onebadvert's Avatar
Good info skunk. You are like a walking mustang encyclopedia!
Old Jun 12, 2012 | 01:06 PM
onebadvert's Avatar
I just like to throw that in. I have seen a few guys run into non s/c 4 banger trannies. I think because they are a little easier to find in the boneyard.
Old Jun 12, 2012 | 01:11 PM
skunk21's Avatar
LOL. I try my best to pass on info.
I wouldn't use a 4cyl T5 behind anything but a 4cyl, they are very weak and a stock V8 can break them.
Old Jun 12, 2012 | 01:18 PM
onebadvert's Avatar
I wouldn't either. You can get away with it on a stock build but that's about it. Plus the gearing is different. :good:
Old Jun 12, 2012 | 01:30 PM
skunk21's Avatar
Gearing is different for starters but I still wouldn't use a 4cyl T5 even on a stock build imo.
Old Jun 12, 2012 | 01:43 PM
onebadvert's Avatar
I wouldn't either. But then again I wouldn't be doing a stock build. . May as well do it right the first time.
Rando
Sep 30, 2015 12:28 PM
JMU
Sep 27, 2015 07:53 AM
trackpack13gt
Aug 8, 2015 11:23 AM
southern stang
Jul 29, 2015 08:41 PM
