sunroof leaking
sunroof leaking
ok my sunroof has a leak just behind the passenger seat, i need to replace the washer that has a lip on it to keep out the rain and i haven't been able to find them so and a junk yard would be a last resort but any help would be appreciated
I'm not sure what you mean... a washer? like a metal ring thats used with nuts and bolts? Or do you mean weather stripping? like this: http://www.latemodelrestoration.com/...weather16.aspx
ok there are two screws that hold the sunroof latch to the cover, and between the the screws and glass there are two washers one metal and another that i think is nylon that has a small lip on it that helps prevent water from seeping into the interior
