ROUgh Drive,,HElP
Old Aug 30, 2011 | 02:40 PM
jonb's Avatar
ROUgh Drive,,HElP
i just got a 92 gt. was driving fine. now it has a rough idle and when driving feels like its struggling or jerking,, or not enough spark. i just replaced the plugs. New throttle sensor, air mass flow.. i adjusted the distributor a little and its better, but now its still a rough idel almost like it misfiresn and when at 45 it kinds of jerks....IDEAS
Old Aug 30, 2011 | 05:03 PM
Planeswalker's Avatar
Check fuses.
Take it to AutoZone and see if there is a trouble code.
Check all lines and hoses, make sure they are all connected and in good condition. Have somebody press the gas pedal, or do it yourself underhood, and listen for a vaccuum leak.
Make sure you properly gapped the plugs, and put them back in properly.
Change fuel filter, or even make sure engine is getting proper fuel pressure.
Thats some common stuff to check.
Old Aug 31, 2011 | 11:13 AM
jonb's Avatar
ive done all that. and replaceed the idle air valve. still runs like crap. the only major change i did was put flowmater on then this happened, wondering if it could be the cats. cause acceleration is half way ok, when i maintain a speed like 45 it kind of jumps while driving or a jerking motion.. so do you think cats could be bad..?? i know it has burned gas like crazy,went fromo full to 1/2 in about 30 miles maybe.. havent checked Egr yet..
Old Aug 31, 2011 | 11:55 AM
jonb's Avatar
TP circuit below minimum voltage..MAF circuit below minimum voltage...Secondary -Air Injection Diverter (AIRD) solenoid circuit failure...Secondary Air Injection Bypass (AIRS) solenoid circuit failure
what do i need to replace to fix this
Mpaps
Oct 11, 2017 08:06 PM
FromZto5
75
Oct 5, 2015 02:27 PM
oldnjguy
Sep 10, 2015 02:39 PM
Road_Runner
Sep 10, 2015 01:14 PM
Road_Runner
Sep 10, 2015 11:28 AM
