Rebuilt motor
Old Jan 8, 2012 | 11:07 PM
87fox5.0's Avatar
Rebuilt motor
Whats the average cost to rebuild a 5.0 motor thats built up?
Old Jan 9, 2012 | 05:32 AM
skunk21's Avatar
explain built up? like has aftermarket heads/cam/intake that kind of stuff? what needs to done cylinders cleaned, new rings, bearings or bored?
Old Jan 9, 2012 | 02:49 PM
It does depend on a lot of things. Does it need to be bored? Does the crank need to be turned or replaced? Does it need head work? Do you plan on replacing the intake and carb or one or the other? Do you want to go with a stroker kit? Are you going to go with new headers or use the stock exhaust? You will need some new hardware and a gasket kit. Will you be doing the take down and reassembly yourself or will you be paying someone to do it for you. If you do it yourself for the most part you could probably get it done for under 2k easy.
Road_Runner
Sep 2, 2024 04:46 PM
09-gt/cs
Oct 15, 2015 10:03 AM
Evil_Capri
Sep 25, 2015 12:56 PM
BigHoss
Sep 21, 2015 10:03 AM
dbent15
Sep 5, 2015 12:15 PM
