no oil pressure
Old Jul 11, 2010 | 02:37 PM
19905.0's Avatar
no oil pressure
Hello, I have a 1990 gt 5.0 , the car was running fine then all of a sudden it has no oil pressure, It still starts up fine but now you can hear the lifters ticking, Would this be the oil pump? What else can I check?
Old Jul 12, 2010 | 12:33 PM
BoogieNights's Avatar
BoogieNights Studios:
Official Fluffer
It can be the oil pump or a couple different things. What kind of oil filter are you running?? Have you tried to change the filter to see if you get oil pressure back??
Old Jul 12, 2010 | 05:23 PM
HOSS429's Avatar
legacy Tms Member
quite possibly broken oil pump shaft .. happens on fords quite often .. specially older ones with cracked valve seals that wind up in the oil pan
Old Jul 12, 2010 | 06:38 PM
blupastu408w's Avatar
First thing you need to do is make sure your oil pressure gauge is still hooked up and the wire didn't get toasted by the header. The wire is actually two pieces in (some) cars and also disconnect right around the #5 cylinder (well, near the #5 injector).
that would make the most sense to me. Once you check that and everything is good, if you still don't have oil pressure then like the above poster said, my guess is that you spun the oil pump driveshaft. It is a common occurrence and is easy to fix. I wouldn't use a junk replacement though, get the steeel driveshaft that SVT carries. Its much beefier than the crap you get at the auto parts store. Oh, and change your oil
Old Jul 14, 2010 | 02:34 AM
hi5.0's Avatar
And another thing that could be considered is the oil pressure sender - though you did mention the lifters are now making noise. When you start the car now, does the oil pressure gauge needle move into the normal range, read low, or no indication at all? As others have mentioned, sounds like oil pump/pump drive shaft failure. ARP also makes a heavier duty oil pump drive shaft as well. If the pump failed, replace both it and the pickup together.
Old Jul 14, 2010 | 09:54 AM
by the way, its easy to see if the oilpump driveshaft is broken... just pull the distributor and look down in the hole. There's another smaller hole where the oilpump driveshaft sits into the bottom of the distributor. If the hole is empty then you got yourself a broken driveshaft.
14Glassback
Oct 4, 2015 08:52 AM
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
