Manual to Power Seat Swap Question.
Old Jan 29, 2012 | 08:15 PM
FourEyed's Avatar
Hello there.. I need to know what is the easiest place to tap for 12v power in my 86 GT, in order to connect '02 power seats.
Is the cigarette lighter a good idea to tap into?
Or what fuse # in the fuse box?
Maybe a direct wire to the battery?
Anyone here done such swap?
Thanks in advance.
Old Jan 30, 2012 | 08:37 AM
skunk21's Avatar
most people have done it through the cig lighter. I have never done one but all it needs is a 12v constant and ground to work the seat motor.
Old Jan 31, 2012 | 09:37 AM
FourEyed's Avatar
Thanks bud.. I look into that route then. Or may just run a wire to the batt with a fuse and call it a day.
Old Feb 1, 2012 | 04:21 PM
delz05's Avatar
Usually the wiring and connector is sitting under the carpet, below the seat... have a look.
If not, splice into the wiring harness that runs against the inner rocker panel on the drivers side.
Old Feb 1, 2012 | 04:37 PM
skunk21's Avatar
'92 was the 1st year the fox was offered with a power seat if that is the harness you are refering too so he doesn't have one. I asked if he had power lumbar that harness would be there. It is easy enough to wire a nice clean setup for a 12v source once he has the seat out .
Old Feb 16, 2012 | 09:18 PM
SleepingStang's Avatar
Here is a swap I did. Maybe it will help.
http://www.mustangevolution.com/forum/f142/t292818/
Old Feb 19, 2012 | 06:55 PM
FourEyed's Avatar
This is the best info I've found so far...Although I don't have power under my seat, it's a good starting point.
iliveonnitro
Oct 7, 2021 06:31 PM
FromZto5
75
Oct 5, 2015 02:27 PM
jim010
Sep 14, 2015 10:15 PM
