i need advice on my blower setup please...
Old Dec 10, 2010 | 07:52 AM
afr347strokerman's Avatar
So I have a 347 10:5:1 comp afr 185s custom grind cam (.600lift yada yada) my setup was for natural aspiration/nitrous
But I couldn't help myself and bought a novi 1500 renegade style blower that's setup for 14lbs. Now I have a full msd setup 6al box, dist, coil,wires, a full aeromotive fuel system, 60# inj/ mass air.
My question is what's the safest way to run this setup. My block is stock. I have no problem sprayin meth and retarding the timing cause the car will see the street on weekends but I want 10s at the track...can I? Thanks
Old Dec 14, 2010 | 12:07 AM
lxlaw's Avatar
Well you have 2 issues. The stock block and 10+ compression. The block is good for about 500 rwhp at 6500rpm. You can get more, you are pushing it though. That high comp. is a problem. You will have to run some low boost, or some serious fuel. It can be done though. Just bout 7-8 lbs safely with good tune. Intercooler???
Old Dec 14, 2010 | 12:38 PM
For fuel I have a full aeromotive system...dumped tank...a1000 pump...braided lines....regulator and rails etc...I however don't have a intercooler. That's why I either want to spray meth or a small dry shot of nitrous(10-20 shot) ima run 12-14lbs minimum...input? I know its a time bomb but until I can her the dart block $$$$$ I wanna be as safe as possible. Input?
Old Dec 17, 2010 | 08:39 AM
lxlaw's Avatar
Well I would think with meth injection it would be ok, just control your timing.
Old Dec 18, 2010 | 07:48 AM
lxlaw's Avatar
Just be aware 14lbs with 10.5 compression is a lot if pressure. It is a bomb. Dart has some bad *** shortblocks for about 3500 with their sportsman block. Really nice setups.
FromZto5
Sep 30, 2015 05:28 AM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Airborne42
Sep 25, 2015 05:14 PM
MustangGTCS13
Sep 17, 2015 07:38 AM
