help, my car is dying
Old May 6, 2008 | 04:51 PM
touring's Avatar
well.... i changed the maf sensor and guess what? nothing...still the same problem.Then i changed the tps and guess what? nothing.....still the same problem.
heres a vid please help
the first start up is regular
the 2nd is with me giving it gas then letting go
http://www.youtube.com/watch?v=7RJtlPOlIDI
At this time i think they are the injectors.
Old May 6, 2008 | 07:34 PM
GT5088's Avatar
it could be a bad or stuck injector (s)... I mean, it's kinda hard to gather alot of info from a video. I am no mechanic, but I have screwed around with GM and Ford engines and have had problems with bad injectors and it sounded like that...but it could be something else
if it's not that, I would really consider taking it to a Ford dealership or trying to find someone who is a Ford mechanic or see if any of your friends know one. The reason I suggest that is because it seems as though there aren't any real good auto shops near you where you can take a vehicle and get it fixed right. It would make more sense in the long run to maybe pay a thousand dollars or so to get it fixed rather than throw money at it ya know..
If you don't have the means to pay for that, I would try to find someone who has one of those diag programs to see whats up with it
Old May 6, 2008 | 09:39 PM
hi5.0's Avatar
Originally Posted by MSP
I have never had my Injectors cleaned. They are now roughly 3yrs old and working perfectly.
Can you explain the process of having your injectors cleaned, and who advised you to pursue such a dangerous course of action?
On that note, let me just say I have completely no faith in any of your fuel injectors, and would suggest that since they have been cleaned, its probably a good idea to to replace all of them.
Leave the injectors dirty, don't let anyone clean your injectors. They are probably sticking.
Here: http://www.cruzinperformance.com/injsteps.html
Best advice, get the car hooked up to a diagnostic tool or scanner and see what kind of codes come up. IIRC, You can also do this yourself with a voltmeter or the cheap code reader with the flashing red LED light. (Think I still have mine buried somewhere... ) I'd also throw out the possibility of a bad 02 sensor or maybe a faulty fuel pressure regulator if you want to "throw parts at the problem" - but still, IMO better to get it checked for diagnostic trouble codes at a competent repair shop.
Old May 7, 2008 | 10:05 AM
jacostang's Avatar
Was it ok before you had the injectors cleaned??? If it was then one or more has gone bad... Cleaning old injectors like MSP said doesn't work very well at all. How old are they? I replaced all of mine and it runs like a new car again! My 87GT was running rough adn would actually backfire a bit, changed wires, plugs etc and nothing, finally took out one of my injectors and it fell apart in my hands. Make sure that the passages are clean as well..
Old May 7, 2008 | 03:34 PM
GT5088's Avatar
I've never really have ever heard of people cleaning injectors, I have only replaced them..
Old May 7, 2008 | 05:30 PM
touring's Avatar
Problem sovled
Old May 8, 2008 | 07:09 AM
GT5088's Avatar
what was it?
Old May 8, 2008 | 10:07 PM
hi5.0's Avatar
TPS?
Ecostang
Nov 3, 2022 08:50 PM
jc46002003
Apr 15, 2016 03:00 PM
jim010
31
Sep 14, 2015 08:39 PM
f1-cobra
Aug 1, 2015 08:02 PM
roushcollection
Jul 28, 2015 02:08 PM
