fuel pump for my 88 GT
Old Apr 29, 2008 | 08:30 PM
Valentino's Avatar
Originally Posted by GT5088
As far as I know, I don't think I have speed density, mine is an '88...well, the way you describe it, it shouldn't be too involved...I have been wanting to get this squared away because I purchased the Trick Flow Street Heat top end kit (upper and lower intake, heads, cams, roller rockers, etc.) and I don't want to install that kit until I square everything else away. So, I figure installing a new ignition, cap, rotors, wires, alternator and radiator would be the right way to prepare for such an addition. I replaced my fuel pump with the one Trick Flow dynoes that kit with, and they dynoed it with a 306 block and pulled 360 horse, so I know I will be over 300HP...I haven't and will not install that kit until everything else under the hood is ready for such a modification...
'88 California cars were mass-air equipped, if you don't have SD then you should have a MAF meter like the one circled in the pic of my motor.
If you do still have SD you almost have to convert to mass-air to get it to run properly after that cam swap. Theres like 2 guys at stangnet who swear they have h/c/i swaps still with SD and it runs fine but everything will be easier if you have MAF.
Old May 4, 2008 | 02:50 AM
hi5.0's Avatar
Originally Posted by Valentino
I've read quite a few posts at stangnet about the MSD coil making some kind of whining noise or something and besides that I couldn't find another coil that put out as many volts as the Screamin' Demon so thats what I got it.
Don't mean to jack the thread, but I just put the MSD coil in and it makes RF noise that matches revs - you can even hear it from outside the car with the hood closed and engine running. (Stock exhaust) Loud(er) exhaust or turning up the sound system, won't notice.
NC14GT
Feb 20, 2023 09:42 AM
Sep 16, 2015 06:44 PM
Beouch
Sep 16, 2015 06:14 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
