Carb to fuel injected
Old Sep 26, 2011 | 09:22 PM
Tirefryer's Avatar
This is prob a old ? But i couldnt find a thread on it. After a long search i finaly found a 351w out of a bronco but its carb and i would like to stick with fuel inj has anyone converted, can it be done easy, can i bolt on all my 302 efi stuff and just use the block of the 351w , i have gt 40 heads to bolt on and cobra intake of a 302 will it work or is it better to stay with the carb on the 351 any info would help... Thanks
Old Sep 27, 2011 | 02:23 PM
dcpirani's Avatar
A 302 intake will not fit a 351. The heads will work, but you may need to have them machined for 1/2 head bolts. The 302 uses 7/16 bolts. Due to taller deck height, you will need to get 351 headers to use in your Fox. BBK makes them (part #1511) as do others. Good luck and keep us posted on the progress.
Old Sep 27, 2011 | 02:46 PM
hi5.0's Avatar
and there is the question of the cam & valvetrain. with bigger displacement, you could easily step up to a "larger" cam, but, older 351W engines used flat tappet lifters - the last 351Ws that had OEM hydraulic rollers are considered the weakest castings. oil pan will have to be changed to fit Mustang K-member and so forth. more interwebz search-jutsu practice needed. here's one link that should help: http://www.turbomustangs.com/smf/ind...?topic=53597.0
Old Sep 27, 2011 | 10:42 PM
JPCooter's Avatar
You definitely need to have the GT40 heads drilled, I ran into that same problem. If you want to keep it fi then order the efi lower to fit the 351and use the 302 upper and accessories. you will also need a flywheel and harmonic balancer to fit, the 351 is a 28 oz imbalance and the 302 is a 50 oz.
I'm doing a 351 conversion in my 86 but Im going with a carb and I ran into the prob with the flywheel. Only a couple of companies make the right ones for the conversion, I used Ram and it ran $279. summit has the oil pan and pickup for the conversion.
Good luck with it, you'll have fun with it.
Old Sep 28, 2011 | 06:26 AM
Tirefryer's Avatar
Rumor has it the sway bar or some crossmember neads changed as well. Is this true or not.. Hope its a rumor and its just the oil pan fix....
Old Sep 28, 2011 | 08:44 AM
JPCooter's Avatar
You shouldnt need to change the crossmember or sway bar, the pan should be it. Ill be dropping mine in this weekend so I'll let you know (providing my flywheel gets here from Summit).
Old Sep 28, 2011 | 03:13 PM
dcpirani's Avatar
With the right oil pan, the 351 will bolt right in. Same mounts and bell housing as the 302.
Old Sep 29, 2011 | 08:24 AM
Tirefryer's Avatar
K... Tell me how ur swap goes if u have any hickups.... I bet u cant wait.... Im pickin my motor up this friday so she prob wont go in till next summer but im itchin bad to drop her in but want to do it wright
NC14GT
Feb 20, 2023 09:42 AM
Fastnloud
Feb 15, 2016 05:21 PM
Sep 16, 2015 06:44 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
