Alternator replacement help
As I started her up today, it hesitated so I immediately checked to see if I had left my lights on, no go. As I was driving, I noticed the amps were low plus I heard a whine coming from the engine plus I could feel it through the pedal. Took it to autozone and rule out the battery so I took the chance and made it home thankfully. I can also smell a faint burning smell coming from it which is a pretty good indication also I guess lol
Now I can either take it to a mechanic or replace it myself. It appears to be a pretty straightforward bolt on but I remembered back when we had probs with it years back that you have to allign something correctly otherwise it will not work.
So does everyone think I should replace it myself and if so, do you have any tips? If not, I guess I'll be taking a trip to the mechanic
Thanks for the suggestions
It's been a while since I replaced an alternator on a 5.0, but it was a pretty easy job with simple tools. The belt tensioner made it pretty simple to remove the belt. Just add a little elbow grease to lift the tensioner to remove/install the belt . . . again from what I remember.
Pretty straight foreward, put a 1/2 inch drive ratchet in the tensioner and lift up to remove the belt. Next just a couple of bolts and you have to put a new connector on for the warrantee which should come with it!! Piece of cake!!!!
I ended up talking a friend of a friend who told me where it was. I felt pretty stupid for not knowing something so easy but I had never changed one before. Once I found the location, it took me less then 30 minutes to change it lol
Thanks for all the help
Anytime!!!!
Rando
8/25/21 11:12 AM
PonyMuscletang13
9/29/15 09:40 AM
