Alternator replacement help
Old Jan 8, 2007 | 03:30 PM
Stangfriik's Avatar
As I started her up today, it hesitated so I immediately checked to see if I had left my lights on, no go. As I was driving, I noticed the amps were low plus I heard a whine coming from the engine plus I could feel it through the pedal. Took it to autozone and rule out the battery so I took the chance and made it home thankfully. I can also smell a faint burning smell coming from it which is a pretty good indication also I guess lol
Now I can either take it to a mechanic or replace it myself. It appears to be a pretty straightforward bolt on but I remembered back when we had probs with it years back that you have to allign something correctly otherwise it will not work.
So does everyone think I should replace it myself and if so, do you have any tips? If not, I guess I'll be taking a trip to the mechanic
Thanks for the suggestions
Old Jan 8, 2007 | 04:47 PM
replace it yourself .... Pretty straight forward. Do you know how to get the belt off?
Old Jan 8, 2007 | 05:04 PM
Evil_Capri's Avatar
It's been a while since I replaced an alternator on a 5.0, but it was a pretty easy job with simple tools. The belt tensioner made it pretty simple to remove the belt. Just add a little elbow grease to lift the tensioner to remove/install the belt . . . again from what I remember.
Old Jan 9, 2007 | 05:11 AM
Stangfriik's Avatar
No I have never taken the belt off before so suggestions would be helpful.
Thank you
Old Jan 9, 2007 | 12:42 PM
Stangfriik's Avatar
this is gonna sound stupid but I'm having a problem finding the tensioner to remove the belt so I can't even start lol
Old Jan 9, 2007 | 04:47 PM
Valentino's Avatar
here's where the tensioner is located, I also added the locations of other important parts that come stock on 5.0s.....
Old Jan 10, 2007 | 02:52 PM
jacostang's Avatar
Pretty straight foreward, put a 1/2 inch drive ratchet in the tensioner and lift up to remove the belt. Next just a couple of bolts and you have to put a new connector on for the warrantee which should come with it!! Piece of cake!!!!
Old Jan 11, 2007 | 03:52 PM
Stangfriik's Avatar
I ended up talking a friend of a friend who told me where it was. I felt pretty stupid for not knowing something so easy but I had never changed one before. Once I found the location, it took me less then 30 minutes to change it lol
Thanks for all the help
Old Jan 11, 2007 | 04:25 PM
jacostang's Avatar
Anytime!!!!
lakersfreak
Jun 13, 2022 12:29 AM
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
