93 notchback problem wtf??!!!
Old Sep 23, 2012 | 04:38 PM
landyachtzrider91's Avatar
93 notchback of mine is having difficulty starting and holding an idle without sputtering/back firing and dying. Also back fires and sputters when any load is applied proceeded first by a hesitation. Ive checked my fuel filter. Fuel pump. Distrubutor and timing. I have a clean MAF. Throttle position sensor is correct. Im completely stumped. Anyone know wtf is going on?
Old Sep 23, 2012 | 11:10 PM
Fox85's Avatar
Kinda sounds like how my stang was awhile ago. I'd check all gaskets, and fuel injectors
Old Sep 24, 2012 | 05:30 PM
91notchback's Avatar
Check all of your vacuum lines too. I ran into that problem a while back.
Old Sep 24, 2012 | 06:58 PM
NoHandles13's Avatar
Check your map sensor
Old Sep 24, 2012 | 07:46 PM
delz05's Avatar
Could be a timing issue or perhaps the timing chain jumped...
Old Sep 25, 2012 | 12:19 AM
hi5.0's Avatar
+1 and check for vacuum leaks in general in the intake manifold vacuum fittings and the area it attaches to the heads and where the upper & lower portions join for good measure. Especially if those have been removed or replaced recently.
Rando
Aug 25, 2021 11:12 AM
Mpaps
Oct 11, 2017 08:06 PM
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
