93 2.3 spark plugs
Old Dec 23, 2013 | 05:53 PM
mustangIIfan's Avatar
93 2.3 spark plugs
i need to replace my spark plugs on my 2.3 i have the 8 plug system. any one have any suggestions on how i can get to the ones on the driver side of the head?
Old Dec 23, 2013 | 07:34 PM
pebkac's Avatar
Easy! Plug wire pliers, new plug wires, Spark Plug socket with rubber insert 1/4 drive long long extension. Straight shot to all of them once you get the wires off. New wires as I have had all of mine stuck on and ended up ripping the boots.
Old Dec 24, 2013 | 11:49 AM
im talking about the 4 plugs on the driver side of the head the upper intake runs over them and makes it nearly impossible to access them with extensions. i dont trust swivels to well especially on something as delicate as plugs
Old Jan 10, 2014 | 07:31 AM
5litereater's Avatar
I did it with a swivel and extension didn't hurt the car. That's the only way you can get them out without taking apart the intake
Old Jan 12, 2014 | 08:41 AM
pebkac's Avatar
I was also #1 simple to get at once you clear the alternator. Simply loosen and flip out of the way. #2 only slightly difficult with extension due to throttle cable linkage mount. #3 extension right between the intake runners. #4 just get the extension through the fuel rail area and you are home free. I didn't use a single swivel. Light is your fiend so you can see the plug angle cake....
Evil_Capri
Sep 25, 2015 12:56 PM
Sep 23, 2015 03:21 PM
devildog1679
'10-14 Interior and Audio
Sep 14, 2015 02:17 PM
